| Latest | 0 Rplys |
02-09-2009, 09:06 PM | #1 | |
Rag joint eliminator?
Anyone put one on their steering system? are they worth it? im looking to get one cause my steering isnt as responsive as it should. I replaced the gearbox not too long ago. They look easy to install from this pic
2006 Chevy Cobalt LS |
02-10-2009, 02:33 PM | #2 | |
Re: Rag joint eliminator?
It may be your joint needs replacing...the eliminator joint would cause you to feel all the road defects in the steering wheel...
I would also check your front end componets for wear , as well as the control arm bushings, sway bar bushings and links... |
02-10-2009, 02:45 PM | #3 | |
That was my only concern with the eliminator, that it might be too touchy. i had the tie rod ends replaced, along with the sway bar bushings, everything else seemed to look good. if so ill prpbably go with a new rag joint rather then the eliminator
02-10-2009, 08:11 PM | #4 | ||
if oils/brake fluid dripped on this it is very possible that the material is no longer good... |
