Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 01-03-2009, 11:37 PM   #1
teegolf
97 Lumina will not start
Need help with my 1997 Lumina with 3.1 engine. Engine will not crank over with the key. Battery tests good and all other electrical functions seem to work OK. I can jump the starter wire at the solenoid and the car will start and run for about five seconds and then die. Somehow I am not getting current to activate the solenoid at the starter. Anybody got any ideas?
Thanks
teegolf is offline   Reply With Quote
Old 01-04-2009, 09:41 AM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Re: 97 Lumina will not start
What does the "SECURITY" lamp on the instrument panel do when the ignition is turned on?
Blue Bowtie is offline   Reply With Quote
Old 01-04-2009, 11:10 AM   #3
teegolf
The security light is flashing with the key on.
Old 01-04-2009, 01:01 PM   #4
Blue Bowtie
Registered Offender
The SECURITY lamp should stop flashing after about 4 seconds. If it doesn't, the VATS/PassKey system is not detecting the correct key pellet resistance. When that occurs, the engine will not start.
This page might help:
VATS System Diagnosis
Old 01-04-2009, 05:08 PM   #5
teegolf
After testing found I had an open circuit in the two wires going up the steering column to the switch. Resistors in keys checked out. Wound up installing appropriate resistors in the key sense wire and bypassing the contacts in the switch for the key. All works and starts now with security light going out. Thanks for the help.
