| Latest | 0 Rplys |
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
#1 | |
Ran great but now won't start after parking overnight. Has ignition, fuel (pressure up to rail anyway), MAF valve good, timing good, exhaust is free, compression good. Out of ideas.
Shop had it for 2 weeks and gave up. Tried to get a code but no luck. Going nuts on this one. ![]() |
#2 | |
![]() Join Date: Dec 2008
Re: 1988 toyota camry won't start
Have you tried putting gas or starter fluid in the intake to see if it starts to run?
1988 Plymouth Voyager 2.5L Straight-4 100HP w/ conventional 10W40 3 forward speed auto trans No power windows ![]() ![]() Andrew Jackson never really cared for centralized banking. |
#3 | ||
Nothing scares me anymore
![]() Join Date: Dec 2003
Remove a fuel injector. Leave it plugged in and crank the engine. Does it give a fuel spray pattern? Also, I have encountered ignition components (spark plugs, plug wires, ignition coil) that were marginal, and about to fail. They would produce a spark when the plugs were tested in the open air, but inside the combustion chamber, the pressure build-up prevented an adequate spark. Usually these items, in their last few minutes of life were able to keep a running engine going, but did not work on cold - start up. |
#4 | |
A990 racer
![]() Join Date: Mar 2002
As usual we are giving advice that is basic in nature as these tests seem not to have been done, there is a relay that triggers the fuel pump circuit called circuit opening relay that powers up the ecu too, common issue on those cars/trucks, but we still do not know if there is injector pulse and/or fuel delivery. Check this link for some helpful info. ..http://www.autozone.com/shopping/rep...00c152801ccc4f
