Go Back   Automotive Forums .com Car Chat > Buick > Roadmaster
Old 11-11-2008, 11:54 PM   #1
jase386
Send a message via AIM to jase386
1995 signal flasher
Where is the location of the turn signal flasher in a 95 roadmaster. after replacing all of the light bulbs in the car, now the turn signals dont flash.
the manual shows a flasher location in the dash fuse block, but its just a fuse, and its good.. so i cant figure out why the signals dont flash and the reverse lights dont light up.
jase386 is offline   Reply With Quote
Old 11-13-2008, 09:52 AM   #2
jase386
Re: 1995 signal flasher
just incase anyone else has this problem
its under the drivers side kick panel where the fuse box should be on a normal car.
Old 09-10-2013, 08:23 AM   #3
charlie carter
Great reply and I know this is old post but how do you remove rear lens cover to replace tail light?Thanks
charlie carter is offline   Reply With Quote
