| Latest | 0 Rplys |
#1 | |
trunk release button inside car not working...help
I have a 1998 es300 that all of a sudden the trunk release button on the dash won't work. The gas tank release button right below it still works. Any ideas? Thanks
#2 | |
![]() Join Date: Feb 2006
Re: trunk release button inside car not working...help
If you have already checked all fuses relating to trunk latch operation, your next step should be to test your trunk lock accuator to see if it has power.
#3 | |
The RustBuster
The dash button itself could be worn out or the contacts inside covered in oxidation. Test to see if you are getting voltage to the button, too. Then go and test to see if you get voltage to the trunk actuator when you bypass the button with a test wire (do this only intermittently...have a friend watch the voltmeter).
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
#4 | |
Thanks for the help...I did get it to work. Now next problem....the front end has a noise that would seem like a shock or something. I found something about sway bar bushings online making a noise. Any advice or ideas?
