| Latest | 0 Rplys |
05-15-2008, 01:02 PM | #1 | |
Check Engine Light question
The Check Engine light came on in my 1999 4Runner and I took it to the Service department at the dealership. They called to inform me that the problem was the catalytic converter and it would need to be replaced--for $1500. I decided to try and have my neighborhood mechanic do the work instead for much less. When I called him for an estimate, I mentioned that the Check Engine light had not come on since I picked up the car, which had been 3 days prior. He said to wait until it did, then bring the car in and he could do the work for $900. As of the the Check Engine light is still off and it has now been three weeks. Was the original trouble a fluke and I don't need repair? I'm worried because I have long car trip coming up and I don't want to break down.
05-15-2008, 08:49 PM | #2 | |
AF -Advisor
Re: Check Engine Light question
If the CEL has not come back, i would not worry about it.
The OBDII system is not perfect, and can generate false codes.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
05-16-2008, 09:37 PM | #3 | |
Resident Chemist
Even if you had a code for a bad cat converter, the odds are that it is the HO2 Sensor 2 which is at fault and not the cat converter. The ECM determines the quality of the cat converter by monitoring it with the HO2 sensor after the cat converter.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
