Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 05-13-2008, 11:54 AM   #1
Andreas_Utah
93 Lumina 3.1 TCC replacement
After reading many of the threads and doing the tests recommended by many, it is clear that my TCC Selenoid has gone bad. Is there a simple way to replace the faulty one? I've read that it requires dropping the engine slightly to get to it, but I don't think I have the tools necessary to hold up the engine while I do that. Is there any other way? thanks...
Andreas_Utah is offline   Reply With Quote
Old 05-13-2008, 07:48 PM   #2
1991lumina
Re: 93 Lumina 3.1 TCC replacement
I just unplugged my TCC and its been unplugged for a year now and it runs just fine
1991lumina is offline   Reply With Quote
Old 05-19-2008, 02:00 PM   #3
Andreas_Utah
With the TCC unplugged, the car stays in 3rd gear. I have to manually shift from second into 3rd. It will not go into 1st with it unplugged. Is this similar to what you are experiencing?
Old 05-20-2008, 01:31 AM   #4
1991lumina
Before I unplugged my TCC it would surge when I tried to take off but after taking off and having it die couple times it would run fine until i slow down and stop and try to take off again, after I unplugged it, it never did it again and I have never had a problem with it shifting or anything
The Following User Says Thank You to 1991lumina For This Useful Post:
jamespa48 (02-21-2011)
Old 05-22-2008, 08:05 AM   #5
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
This isn't right. You sure you didn't unplug the shift solenoids? That's what it sounds like...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 05-23-2008, 11:12 AM   #6
savannaz34
LOL
savannaz34 is offline   Reply With Quote
Old 05-23-2008, 04:49 PM   #7
richtazz
stupidity should hurt
richtazz's Avatar
A 91 Lumina could have a 4L60 trans, which has a vacuum modulator and a 4 wire TCC switch. On those models, you can just unplug it and all you'll lose is lock-up. On the 93 Lumina, it has the 4L60E electronic transaxle (optional on the 91 also) with the 6 wire TCC plug. Since this plug also controls the shift solenoids, you cannot just unplug it or the car will go into limp home mode which is 3rd gear.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
richtazz is offline   Reply With Quote
The Following User Says Thank You to richtazz For This Useful Post:
jamespa48 (02-19-2011)
Old 05-28-2008, 03:01 PM   #8
Andreas_Utah
Thanks for that information. I do have that 6-wire and that's exactly what happens. I feel like I'm driving my grandpas old '53 Dodge pickup with the H-shift on the fly.
I guess I better get this car up on the blocks. The fuse for the TCC also controls the primary cooling fan, so I am not getting out of this one easily. I suspect that the gasket that keeps fluid off these 2 selenoids has gone out and fluid is getting in there and shorting them out. Is this a Saturday afternoon job that I won't loose my religion over, or should I bring this into the shop and let them do it. I just replaced my Ignition Control Module , so compared to that, what?
Thanks again.
Old 05-28-2008, 08:30 PM   #9
jeffcoslacker
...empty gun rack.
Old 02-19-2011, 09:21 PM   #10
jamespa48
I have a 1991 lumina euro. It just started the brake and stall thing - I found the plug it is 4 prong- first thing tomorrow I am going to unplug it and see what happens - will let you know what happened.
jamespa48 is offline   Reply With Quote
Old 02-21-2011, 06:11 PM   #11
jamespa48
Thank you everybody for the info about the tcc solenoid stallout when you come to a stop the engine stalls and dies like you did not release the clutch on a standard tranny - I pulled the plug on the side of the tranny - it had 4 prongs (1991 chevy lumina euro 3.1 motor) the car runs perfect - again thank you and thank you automotiveforums.com -
