| Latest | 0 Rplys |
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here. |
04-23-2008, 09:56 PM | #1 | |
acceleration lag
I have an 89 240sx, auto, hb. Everything was fine up until today when i was driving i was having problems. when i accelerate from stop (~700 rpm idle) the tac will go up and the engine will rev but the car will not actually move until about half a second later; somewhat of a time lag. I also noticed that my car almost stalled at one of these starts and that it would shift in and out of one gear (i think 3rd/4th) when its close between them. All this began as of today and I checked the tranny fluid/oil which are both fine.
PS: yesterday i changed my oil, air filter, and tightened one of my fan belts (cam/alternator)
Theres always something wrong with every car.. ALWAYS |
04-24-2008, 06:31 PM | #2 | |
Re: acceleration lag
transmission issue. you may need a rebuild.
04-24-2008, 08:44 PM | #3 | |
update...
Sorry for giving the wrong info but its actually a lag between when i hit the gas and when the engine actually revs up (ie: throttle possibly?). Also, i had a hard time starting my car today; the engine would turn over but it would not start up until i gave it some gas (and its fuel injected). please can someone help im worried about my poor 240
04-29-2008, 04:52 PM | #4 | |
Could be a lot of things, if the engine isn't revving up right away could be the throttle positioning sensor. Could be your MAF, get some maf cleaner and spray that up a bit and clean it off.
Do lower RPMs seem sluggish? make the car chug a little? I doubt this is it, but if your spark plugs are old, maybe they need replacement. Check for vacuum leaks too. |
04-30-2008, 03:44 PM | #5 | |
yeah im thinkin bout just takin it into a mechanic. it seems like a fuel injector problem, possible engine flooding. idle is usually fine (~700 rpm) but when i give it gas it drops down to about 500 rpm and basically stalls. high rpm's are essentially fine
05-01-2008, 04:47 PM | #6 | |
another update.. i checked the ECU and got the ol' 55 (no malfunction). If the ECU says my car is fine, but its not, then I dont know what the problem is! probly a job for the mechanics... if anybody's got any info i would be glad to hear it!
05-08-2008, 09:05 PM | #7 | |
just thot i would post a reply because i fixed the problem. relaced the coolant temperature sensor (to ECU, not gauge). ran me about $50, very easy fix.
08-13-2008, 07:42 PM | #8 | |
i have a 1990 nissan 240sx and i dont have a ecu to fined the problem but i have an idle issue and when i give it gas it boggs down before it picks up. it also has trubble stayin runnin when not in gear. the idle fluxuates as well. plz email me at nathaniel.woodhall@dover.af.mil if u have any ideas what could be the problem..
ps. i changed the plugs wires and oil nothing helped. |
08-16-2008, 03:56 AM | #9 | |
sounds like the same problem I had. replace the coolant temperature sensor (make sure its the right one) its a very easy fix. only cost me about 30$.
