| Latest | 0 Rplys |
04-01-2008, 07:15 PM | #1 | |
Full Tank, april fools
1999 alero fuel sender seems to have gone haywire
I have pulled the tank and looked at the harness connections they look clean and no green at the terminals. I dont know how long this pump assy. has been in this vehicle. The pump assembly is out and looking at it the float lever seems a bit loose. So here i am looking at the two brush/levers that touch the flat plastic or ceramic piece that is the resistor of sorts i guess. ( wished i could see better) Any how i connected the dvm terminals to the two wires of the sender I set the meter on 20k, with the float down I read .31 on the screen hmm ok so slowly go up with the float and what?/?##& .07 smooth thru .31 hmh! So if i keep it close to empty probably 2-3 gallons i will have a full tank but some how if i wait long enough or stare at it hard or possibly lean against the car in the garage the guage drops to empty and the low light comes on. ( what a way to get gas money) if i was 17 again. ?? replace what is the question, I didnt but could check gpm if i knew the spec. Im putting this up for discussion Thanks Last edited by brmax; 04-01-2008 at 10:45 PM. |
04-03-2008, 09:47 PM | #2 | |
Re: Full Tank, april fools
Replaced pump assembly, works great
Later |
04-03-2008, 11:30 PM | #3 | |
out saving the world
yeah 99-00 n bodies hav a malfuntioning fuel sending unit.
Once its replaced they usualy dont screw up and more... usualy
1999 Grand Am SS 3.4 OHV |
