Go Back   Automotive Forums .com Car Chat > Pontiac > GTO > Modern GTO's (2004-2006)
Old 03-25-2008, 04:52 PM   #1
mightymoose_22
mightymoose_22's Avatar
Strut Rub
Anyone around ehre have the problem of tires rubbing against the struts in '04-'06 GTO's?
I just ran into this problem and judging by info all over the net it is a big problem. I had never heard a word about it, just stumbled into it when rotating tires and found worn tires and rub marks on the struts.
I am wondering what has been effective in correcting the problem. Some people have said alignments... which I don't think is the best way. Others have changed strut bushings, which sounds best... I am just wondering how the results have been after making repairs.
Any info? Thoughts?
mightymoose_22 is offline   Reply With Quote
Old 04-01-2008, 05:10 AM   #2
GTX Playa
GTX Playa's Avatar
Send a message via Yahoo to GTX Playa
Re: Strut Rub
I had strut rub on my GTO, a simple alignment took care of it.
GTX Playa is offline   Reply With Quote
Old 04-05-2008, 08:55 AM   #3
mightymoose_22
Re: Strut Rub
Well so far an alignment has taken care of it... I am worried that it will happen again though and maybe I won't be lucky enough to notice it in time.
I found lots of info on the net about the strut bushings being bad which caused strut rub. I wonder if the bushings are bad but the alignment correction is a simpler fix. I haven't taken my strut apart yet... not sure if I want to mess with it. I am going to wait a few thousand miles and see how the tire wear looks.
Old 06-03-2009, 08:07 AM   #4
clintisghey
Re: Strut Rub
From what I understand, this was a result of shipping to the US. The cars were strapped down tightly enough to bottom out the struts, then when the boat hit waves, the cars had no bounce.
clintisghey is offline   Reply With Quote
Old 11-26-2009, 12:14 PM   #5
The Silver Goat
The Silver Goat's Avatar
Re: Strut Rub
I replaced all the rubber bushings on the front with urethance (pedders) and used wheel alignment specifications from another web site. Worked out the best as I can bury her in corners now and have not rubbed the struts.
The Silver Goat is offline   Reply With Quote
