Go Back   Automotive Forums .com Car Chat > Honda > CR-V
Old 01-18-2008, 07:56 PM   #1
mechhound
Question for those who change their own oil?
What do you use to loosen the old oil filter and tighten the new oil filter, if necessary to tighten more than hand tight? Do you have one of those cap wrenches that fit over the end of the filter? If so where did you buy(find) it? Pretty tight quarters on the 2000 CRV it looks like. I think it would be pretty easy with one of those end cap tools though. Any comments or information appreciated, thanks.
mechhound is offline   Reply With Quote
Old 01-18-2008, 08:23 PM   #2
cannotoutrunme
Re: Question for those who change their own oil?
Use one of the craftmans ban wrenches find at sears small and large size and hand tighten only if you damage the inside of the filter it can cause problems .
cannotoutrunme is offline   Reply With Quote
Old 01-19-2008, 11:17 PM   #3
wiseguy01
wiseguy01's Avatar
the oil filter end cap wrench can be found at autozone also rubber doesnt work that well once u get oil on it
wiseguy01 is offline   Reply With Quote
Old 01-20-2008, 05:11 AM   #4
cannotoutrunme
Exclamation Re: Question for those who change their own oil?
This is oil restant and made to do this . Have you ever worked in a chemical plant probley not.
Old 01-20-2008, 08:47 PM   #5
wiseguy01
wiseguy01's Avatar
(SIZE=5) WELL it MATTER IF ITS OIL RESISTANT OR NOT OIL WILL BREAK DOWN RUBBER REAL QUICK AND THEN CAUSE IT TO CRACK SO YEAH I DONT THINK SO
Old 01-20-2008, 09:23 PM   #6
72chevelleOhio
Oil RESISTANT does not mean oil proof. you don't need to work in a chemical plant to find that out. oil breaks down the rubber, even if its oil resistant. do you work in a chemical plant? PROBABLY not! stay in school!
72chevelleOhio is offline   Reply With Quote
Old 01-20-2008, 10:34 PM   #7
wiseguy01
wiseguy01's Avatar
THANK YOU AT LEAST SOMEONE AGREES WITH ME
Old 01-20-2008, 11:00 PM   #8
72chevelleOhio
yup, if he ever worked in a shop and replaced a set of work boots he would see "oil resistant" means nothing over time.
Old 01-21-2008, 09:27 AM   #9
cannotoutrunme
You people are dumb as all get out hats why I make 7 figures a year There is oil rest-ant rubber I would show you the formula but you would never get it.
Old 01-21-2008, 09:58 AM   #10
jgr7
Would that be like the water resistant watch that you can wash your hands with it on but when you go swimming it fills up with water? Water resistant not water proof!!!
jgr7 is offline   Reply With Quote
Old 01-21-2008, 01:36 PM   #11
cannotoutrunme
What does this have to do with changing oil shows you just how easy simple minded people can be manipulated. This subject is closed, way off track.
Old 01-21-2008, 10:32 PM   #12
wiseguy01
wiseguy01's Avatar
because if you tell someone to invest in a tool thats gonna be of less use then the one that will last alot longer why buy the wrong one insted of the right one also you cannot close threads and or subjects because you are not admin also the idea of a band type wrench is not bad i agree with you there but they also sell metal one that will outlast the rubber ones thats all im saying but if you wanna squash this then lets do because af is an info forum not a boxing ring so im just gonna go ahead and call a truce before this thing gets out of hand
Old 01-22-2008, 10:51 AM   #13
cannotoutrunme
Wink Re: Question for those who change their own oil?
First I did not say buy it. If he did not have clearance for the cap wrench which is better. He can not get a metal ban wrench on it either the new ban you just feed it around slide in place and that it as. But if the cap will go on it with the socket wrench that's great. My god does congress need to get involved.
Old 01-22-2008, 10:53 AM   #14
cannotoutrunme
This has nothing to due with an oil wrench. And you need to stop buying cheap watches. Mine is find I surf dive ect.
Old 01-22-2008, 09:11 PM   #15
jgr7
Once again your high school mentality missed the analogy. You should get back in your 2005 Ferrari Testarossa
2007 Hummer H1
1993 Lamborghini Murcielago
1994 Lotus Esprit V8
and Troll your high school buddies.
