Go Back   Automotive Forums .com Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 01-10-2008, 05:00 PM   #1
J-Ri
J-Ri's Avatar
Travel angle?
When ARC welding from left to right (/ and \ are the electrode):
---> 1.____/____ or 2.____\____
I was reading a welding textbook (I had some ankle problems, I was SO bored doing nothing) for a class I took a few years ago, and it said #1 is correct (I know that's right for MIG). I could have sworn that the teacher for that class said that #2 is correct. We never used the book in class, so nobody ever questioned it. I have welded dozens of things (including suspension braces, caliper brackets, and a new bumper on my truck) using #2 with no problems, but I wanted to verify before I weld something again.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
Old 02-19-2008, 06:00 AM   #2
frankthewelder
Re: Travel angle?
with any flux type electric welding you want to drag the arc behind you (1)
with MIG/gas you can go either way. basically, the angle of the wire directs the heat to some extent. If you are welding thick, drag, on thin you can push or go from one to the other on long welds.
on second thought, stick rods come in three "classes" fast freeze, (for tacking) freeze fill (for general welding) and fast fill.. rods like 7024 fast fill MUST be dragged. for others either is fine.
Turning and burning since 1984
frankthewelder is offline   Reply With Quote
Old 03-04-2008, 05:31 PM   #3
J-Ri
J-Ri's Avatar
Re: Travel angle?
Thanks for the response... kindda forgot about this post for a while. I was using 6012 and 6013 for everything I did.
