| Latest | 0 Rplys |
11-09-2007, 12:51 PM | #1 | |
Temperamantal Door Lock 91 Q45
Hello All.
The drivers door lock is very temperamental. I insert the key and I cannot turn the key unless I jiggle it around for a while. Eventually I can get the key to turn and I am able to lock/unlock the door. The key works fine when used on the passanger door. I also tried a spare key and the results were the same. I am pretty certain the tumbler is the problem since I can feel the key binding on one or more pins in the tumbler. I tried lubricating the inside of the tumbler with graphite which did not help. I want to change the tumbler so my question is this- can I order a new tumbler from the dealer that will match my key or must I buy a tumbler with it's own matching key which would mean I would have to use a different key for each door hence forth? Thanks for your help. |
10-05-2010, 02:02 AM | #2 | |
Re: Temperamantal Door Lock 91 Q45
Try a little WD-40 instead of graphite. You have to use a little WD-40 every week if your locks are that bad.
I think a experienced lock smith can repair the lock while retaining the same key. A local lock smith told me that at least but ask around and see what comes up. |
10-22-2010, 03:49 PM | #3 | ||
Brian 1995 Q45 & Q45t 2000 Q45 |
