| Latest | 0 Rplys |
11-02-2007, 11:41 PM | #1 | |
Replacing Control Panel Lights
2001 Windstar:
The lights that illuminate the control panel in my Windstar have burned out. These are the lights behind the controls for the AC, Fan, Defrost, etc. (not the instruments panel). Any idea how to replace these (or even if they are replaceable). I lost half of the illumination about a year and just recently I lost the other half. Makes it difficult to find any control knob when driving at night. |
02-02-2008, 11:20 PM | #2 | |
Re: Replacing Control Panel Lights
Anyone has any clues what to do about my post above? Are these lights even replaceable? I'll appreciate any hints or ideas.
02-02-2008, 11:54 PM | #3 | |
They should be replaceable. It's just a matter of you being comfortable diving into your dash. The owner's manual should actually identify the bulb number that you need.
There is a trim panel that covers the fasteners that hold your control panel in place, in general. The bulbs should be on the back side of that. If your 2001 is like the earlier model, you have to go carefully over the trim piece for screws, then it's just getting to pop off as it is held in place with posts and spring clips. As a guide, you can go to the Autozone.com repair section. They don't have 2001, so use 98 when you enter in your vehicle. When you finally enter the repair section, you want the body and trim section, instrument panel http://www.autozone.com/az/cds/en_us...rInfoPages.htm and the electrical section, heat and ac, control panel http://www.autozone.com/az/cds/en_us...rInfoPages.htm |
02-03-2008, 12:11 AM | #4 | ||
Disconnect the battery, remove the ashtray, the radio unit and unsnap the panel bezel (around the radio and climate control) Unscrew the climate control and disconnect the rear terminal and remove it from the dash. Then you will have access to the rear illumination bulbs |
02-03-2008, 12:11 AM | #5 | |
I have a '96 and I know they are replaceable that model because I did it myself last spring. I drove around with those burnt-out bulbs for months waiting for it to warm up enough that I could work on those plastic bits without worrying about snapping off clips in -20 temperatures.
No special tools needed except for the radio removal and I had those, and the bulbs are common and inexpensive. Took me about 20 minutes start to finish. |
02-03-2008, 12:16 AM | #6 | ||
02-03-2008, 02:05 AM | #7 | |
Thanks a million to everyone for the quick reply. I'll give it a try.
02-03-2008, 10:53 AM | #8 | |
I removed the ash tray, but I can't seem to get the panel off. I tried prying it off with a screw driver, but it doesn't give in at all. I'm afraid of braking the panel if I pry any harder.
I have the 2001 SEL with the fake wood trim panel. Should I pry harder to pop it off? Do I have to remove the radio before I can remove the panel? Is there any home made tool I can use to remove the radio? I don't have the U-shaped DIN tool (time to go buy one?). |
02-03-2008, 11:19 AM | #9 | ||
02-03-2008, 11:33 AM | #10 | |
The FORD service manual says;
1. Caution the slider knobs are illuminated with LED's. Use care not to damage them when removing the slider knobs. Disconnect the battery. 2. Remove the ash receptacle. 3. Remove the audio unit. 4. Remove the screws. (The illustration shows 2 at the top and 2 at the bottom) 5. Unsnap the panel. 6. Disconnect the connectors. (Illustration shows the rear view of control panel and there are two electrical connectors). 7. Remove the control assembly by removing the 4 screws. 8. To install, reverse the removal procedure. My thought is that if you can see and disconnect the electrical connectors at the rear of the control panel then you should probably be able to unplug and replace the bulb without having to do step 7.
2009 Elantra 2002 Elantra 2001 Windstar 2001 Sienna 1998 Civic |
02-03-2008, 06:06 PM | #11 | |
Thanks.
I removed the ash tray and the bottom two screws. I bought the radio removal tool and inserted into all four holes till they engage, but I can't pull the radio out. Is something else hold the radio and keeping it from sliding out? |
02-03-2008, 06:17 PM | #12 | |
If anything people have a tendency to insert them too far. Insert them a little bit then SLIGHTLY spread them outward and try to pull the unit straight out using the tools as handles. If that does not work try a little deeper and so on.
Until I got that set of tools I messed with coat hangers and such with no success, once I used the proper tool the radio almost fell out on its own. |
02-03-2008, 06:44 PM | #13 | ||
Now I'll go finish the job. Thanks to everyone. |
02-03-2008, 10:37 PM | #14 | |
Fixed following the directions in this thread.
Thanks to everyone for your time and directions. |
11-14-2015, 12:34 PM | #15 | |
Hi, replaced all 4 bulbs today. They were GE 73 bulbs.
1-Pull out radio using Ford u shaped tools-disconnect radio 2-pull out ash tray 3-remove 4 7mm screws (2 on top-2 on bottom) Panel will come out easily. 4-I disconnected all of the plugs on the heater control to make it easier to access the light bulbs but you could do it without doing that. Twist the sockets a 1/4 turn and bulb sockets come out. Pull bulb out of socket, push in new bulb. 5-reverse procedure to put it all back together-pretty straight forward. |
