Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 05-24-2007, 04:14 AM   #1
Coastie John
Is MERCON and MERCON V Compatible?
I think I read on the label of a MERCON V container they were compatible. I don't recall seeing that on the MERCON label. I have the 2000 Winnie.
I don't recall off the top of my head so I'll have to double check the owners manual against the Haynes Manual to see what each calls for.
Thanks....John
Coastie John is offline   Reply With Quote
Old 05-24-2007, 07:01 PM   #2
RickMN
Re: Is MERCON and MERCON V Compatible?
Mercon V is the fluid should be used on 1998 and newer Windstars. It is NOT compatible with older cars
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology.
RickMN is offline   Reply With Quote
Old 05-24-2007, 07:41 PM   #3
Johnny Mullet
Johnny Mullet's Avatar
Send a message via MSN to Johnny Mullet
Mercon V is a synthetic trans fluid and cannot be substituted for Mercon or Dextron or anything else.
Johnny Mullet is offline   Reply With Quote
Old 05-24-2007, 11:49 PM   #4
MARZBX157
MARZBX157's Avatar
The 2000 winnie transmission calls for Mercon V, DO NOT use regular Mercon or it will cause problems. Also, Ford will no longer be marketing the Mercon label as of this year so every vehicle will eventually be using Mercon V. Hope this helps.
2000 Windstar 3.8 V6
MARZBX157 is offline   Reply With Quote
Old 05-25-2007, 09:43 AM   #5
lapin_windstar
So if you have a newer Windstar and you're supposed to use Mercon V, use only Mercon V. But if you have an older Windstar and your recommended fluid is Mercon, it's OK to "upgrade" to Mercon V (in fact, by the end of the year you'll have to because they won't license Mercon any more)?
lapin_windstar is offline   Reply With Quote
Old 05-25-2007, 09:25 PM   #6
wiswind
That is correct.
If the vehicle calls for Mercon V....you MUST use a product that is labeled MERCON V or a product that is labeled as BOTH MERCON V and Mercon.
If the vehicle calls for Mercon, you can use a product labeled as Mercon only.....or MERCON V or Both.
FORD TSB 06-14-4 states this.....and that FORD is phasing out the Mercon fluid....and replacing with Mercon V.
This TSB supercedes former TSB's that stated otherwise.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
wiswind is offline   Reply With Quote
