Go Back   Automotive Forums .com Car Chat > Ford > Aerostar
Old 01-30-2007, 10:33 PM   #1
Ron21
Question 97 Aerostar won't start
My 97 Aerostar 3.0L has developed a wierd problem. When it is cold (below -10 degC) it will not start. When I turn the key on, I hear the fuel pump relay click but do not hear the fuel pump. Also the light for the overdrive displays off. At first I thought the gas line was frozen but that isn't the problem. If I plug the block heater in for a couple of hours, it will start right up. Also the off light for the overdrive is not on and of course I hear the fuel pump when the key is first turned on.
Any ideas what might be causing this? It runs great after it starts.
Thanks in advance
Update
Now I can'y get it to start. Also I notice when the key is in the on postion, the check engine light iis not on like it use to be
Last edited by Ron21; 02-14-2007 at 09:04 PM. Reason: change in the orgional problem
Ron21 is offline   Reply With Quote
