| Latest | 0 Rplys |
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
01-15-2007, 02:28 AM | #1 | |
dynamat question, and another one about a sub's sound
1) Is dynamat really necessary for cars that make vibration sounds on the outside? Isn't the vibration just a result of loose parts, and making everything tight should clear that up?
2) In my car, 2 12" xplods (I don't need to hear the "Sony sucks" comments). They're in a sealed box. For songs that play heavy lows, such as "What you know" by T.I., when it gets to the lowest note, the subs sound...hmm, I just want to say they bottom out of something. It sounds awful, it's hard to describe though. Maybe someone knows what I'm talking about here...what would cause that?
1988 Oldsmobile Cutlass Ciera 2.8L V6 |
01-15-2007, 07:26 AM | #2 | |
Re: dynamat question, and another one about a sub's sound
The subs are going to rattle crap throughout the car no matter how many times you tighten the bolt, dynomat just reduces the vibrations so keep things from rattling loose...as far as your subs "bottoming out", what type of amp do you have? Sounds like maybe you're not getting enough wattage to power them when they are demanding a high amount of wattage.
1995 Camaro 40 Series Flowmaster 2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils) ^Kicker ZX550.2 Amplifier^ |
01-15-2007, 12:40 PM | #3 | |
sony sucks
2001 Ford ZX-2 Alpine CDA-9855 SAX 100.4 Rainbow CMX 265 front stage Stock 5X7 rear fill Hifonics BX1505D TC-5200 |
01-15-2007, 01:46 PM | #4 | |
If it's a power problem, I can understand. I have dual profile hm700 (or something like that) that runs 200RMS@4ohms and 350@2ohms. The sonys are only svc and can only draw off 200 per amp, so it that would make sense (the sonys are 90-380w rms).
Thanks.
01-15-2007, 02:54 PM | #5 | |
OMFG how many times do i need to post this on this forum
YOU DONT NEED FULL POWER TO A SUB TO MAKE IT HIT. All you do is adjust the gains to compensate for the lower power levels, my current setup is running at half RMS they dont bottom out and they hit hard as hell. Ive done it in the past. You dont need to get a bigger amp for those sonys you will blow them with more than 250. And the sound you are hearing is the sub clipping. Your gains are either set to high or to low adjust to fix the problem and o-scope can come in handy. As for dynamat it is a dampener it is used to make sheet metal panels thivker to keep them from vibrating, so instead of the .125"thick sheet metal it becoms closer to 1/2 think. Its there to add a backbone to the metal.
Cant remember who posted it but if you see it give yourself credit Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota. Cardomain |
