Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 01-02-2007, 04:54 PM   #1
phaderus
1999 Water leak on the passenger side
This morning I discovered that the blower motor quit working and the windows were quite frosted. I removed the resistor and water came out. This is the second time in a year that I have had to replcae the resistor. I am curious as to where the water most likely is coming from and how to track down or fix the issue. Thanks for your time!
phaderus is offline   Reply With Quote
Old 01-02-2007, 06:55 PM   #2
xeroinfinity
out saving the world
xeroinfinity's Avatar
Re: 1999 Water leak on the passenger side
Your HVAC drain is possibly pluged.
The drain is located on the firewall,
toward the bottom - right of center.
Heres a pic of the drain tubs(it an elbow that points downward)
http://i28.photobucket.com/albums/c2.../HVACDrain.jpg
You can use a stiff wire to clear it or some compressed air.
Btw- A coat hanger may be to stiff.
1999 Grand Am SS 3.4 OHV
xeroinfinity is offline   Reply With Quote
