| Latest | 0 Rplys |
11-30-2006, 10:02 PM | #1 | |
Blocked Radiator
Hi fellow DIYers,
I am trying to diagnose a cooling prob, and suspect the radiator is clogged. Is there a way of checking the rad for being clogged? Teakstone |
12-01-2006, 07:41 PM | #2 | |
AF - Advisor
Re: Blocked Radiator
Start you vehicle and let it idle up to operating temp (just a couple of minutes after the thermostat opens), turn off vehicle, disconnect battery to keep the fan from coming on, feel the radiator for cold spots.
What are the exact symptoms of your overheating problem? Under what driving conditions? Is the radiator fins free from obstructions and bugs? Old radiator hoses can collapse restricting the flow of coolant. How old is the waterpump? Is the fan operating correctly? |
12-02-2006, 10:31 AM | #3 | |
I just did the diagnosis as yoiu recommended. The rad does have old spots. I am certain that is the prob. Thanx alot
Teakstone |
12-06-2006, 05:09 AM | #4 | |
failed fan viscious clutch is common cooling problem in Aeros also
should have some turning resistance...not tight and not free wheeling usually only last 50>100k miles |
