Go Back   Automotive Forums .com Car Chat > Oldsmobile > Ninety Eight
Old 11-04-2006, 03:19 PM   #1
wab1233
gas smell
i smell gas on the inside of my 94 regency when parked but i have no leaks that i have seen inside the motor compartment and for sure no drips on the ground sometimes the smell is noyhing and other times pretty strong
wab1233 is offline   Reply With Quote
Old 11-07-2006, 12:33 AM   #2
Alibi
Alibi's Avatar
Send a message via Yahoo to Alibi
Re: gas smell
Could be an exhuast leak or a vacuum leak as well. Or your O2 sensor or CTS is faulty and telling the PCM to run the motor too rich on fuel.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Alibi is offline   Reply With Quote
Old 11-07-2006, 03:06 PM   #3
wab1233
Re: gas smell
the proiblem was the test port under the fuel pressure regulater which looks like a valve stem was loose a couple of turns i lucked out. at first when the leak became bad enough where i could see dripping i thought it was the f.p.r. but it seems to be fine now but thanks for at least one reply
