Go Back   Automotive Forums .com Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 09-19-2006, 12:26 PM   #1
D-Bo
D-Bo's Avatar
egr system
just making sure - i checked my fsm and it didn't really explain it for me but i did get a general idea.
exhaust - curved pipe - egr valve - intake
i've been having some overheating going on lately and my egr valve isn't complete so its time to do the last step in my neverending quest to return this engine to stock and end the overheating.. i didn't have the materials after my swap to finish it.. but now i need to get it done because the mighty old emissions test is coming up..
thanks guys
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
D-Bo is offline   Reply With Quote
Old 09-19-2006, 08:05 PM   #2
nissan_240sx
Re: egr system
yup that seems to be the correct order, do you still have yours on?
-Matt
NISMO
1992 240sx SE Fastback 5speed
nissan_240sx is offline   Reply With Quote
Old 09-19-2006, 10:19 PM   #3
therealrayman
therealrayman's Avatar
Send a message via AIM to therealrayman Send a message via Yahoo to therealrayman
Re: egr system
i want to block my egr off, do you just weld the hole shut on the exh. manifold and sticka blockoff plate on the int. mani?
2002 Ninja 250R = Franken-Bike after someone hit it parking and left it there .
1990 Nissan 240sx XE
-Newly machined head just put on.
-Will be back on the street soon...
"My car won't start, what should I do?"
"Did you check your headlight fluid?" <<LOL, I love it.
therealrayman is offline   Reply With Quote
Old 09-19-2006, 10:42 PM   #4
nissan_240sx
Re: egr system
yup, I welded the bend tube from the exhaust manifold shut, removed the egr, and cut out a steel piece to bolt up the intake manifold side. (egr to the intake manifold)
-Matt
NISMO
Old 09-19-2006, 10:44 PM   #5
nissan_240sx
Re: egr system
Oh and I put a gasket in between the steel and intake manifold.
-Matt
NISMO
Old 09-20-2006, 12:07 AM   #6
therealrayman
Re: egr system
any noticed effects? better gas mileage? lol. seriously,though, what was the egr good effect supposed to be?
Old 09-20-2006, 12:20 AM   #7
nissan_240sx
Re: egr system
On cold cold cold mornings I sometimes get hard start ups lol
Probably not gonna feel much haha, but your engine will be happier because the intake manifold will be cleaner =)
-Matt
NISMO
Old 09-20-2006, 01:01 AM   #8
slideways...
slideways...'s Avatar
Re: egr system
well one way to do it is turbo your car
my turbo mani doesnt have a bung and my downpipe only has the O2 bung. and i got a blockoff plate and a gasket for the intake side. but yeah the order is correct.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
slideways... is offline   Reply With Quote
Old 09-20-2006, 02:16 AM   #9
Hit_N_Run-player
Send a message via AIM to Hit_N_Run-player
Re: egr system
i put a quarter in mine (it fit perfect) and then put a plug in on the exhaust side. For the intake side i made a block off plate.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Hit_N_Run-player is offline   Reply With Quote
Old 09-20-2006, 02:31 AM   #10
slideways...
Re: egr system
how cold? well i dont think ill be driving my car in the winter, but what do you mean cold cold cold?
Old 09-20-2006, 12:49 PM   #11
D-Bo
D-Bo's Avatar
Re: egr system
i can still get 500km/tank so i don't think the mileage is any different.. the only real difference i think is the emissions.. no hp difference for sure
Old 09-20-2006, 04:27 PM   #12
slideways...
Re: egr system
nah the emissions systems on modern cars dont take any hp away. even the cats on n/a cars dont restrict flow really at all.
Old 09-20-2006, 05:04 PM   #13
D-Bo
D-Bo's Avatar
Re: egr system
after looking at my fsm, it seems as though it has to do primarily with emissions but is also activated at idle and when coolant temp is really high. its not just that simple but those are the basics as far as i know.
Old 09-20-2006, 09:25 PM   #14
nissan_240sx
Re: egr system
Not winter cold because it never snows here. Like when I forget to park it in the garage, temp. probably like 60 or so when you can see your breath lol. It rarely happens and it can't be my batt. or starter because both are brand new
-Matt
NISMO
Old 10-06-2006, 07:50 PM   #15
klone420
Re: egr system
EGR is use to prevent NOx U get NOx from high combustion chamber heat. U mostly need the egr system to past the visual inspection of the emisions. egr only works at idle and steady cruse.
klone420 is offline   Reply With Quote
