| Latest | 0 Rplys |
Technical Discuss different strategies and theories of the racing aspect. |
#1 | |
![]() Join Date: Oct 2005
Slot drilled rotors on street cars ?
Is there any benefit in installing the slot drilled rotors on the street car ? As far as I can tell drilled rotors can better disperse heat in extreme driving conditions(aka during real road races). So why are people installing them on regular street cars ?
1990 TSI AWD. JDM redtop 4G63T 4 bolt rear end 91 transmission CF hood No-name intake Reverse glow gauges! |
#2 | |
![]() Join Date: Jan 2005
Re: Slot drilled rotors on street cars ?
rice.
all they do on the street is wear out pads faster than normal. the only use would be for daily drivers that race on weekends or something.
#3 | |
they do not wear out the pads faster, whoever told you this was misleading you or just plain lying to you
the reason they are used is because they allow the gases that build up from repeated stops an escape, otherwise they gases would coat the rotors and the pads wont work as well. almost like grooves in a tire to prevent hydroplaning. now if you believe that grroves in the tire wear out the tire quicker try not slicks in the rain or snow, PLEASE, i dare you, then come and tell me, i'm sure the difference would be LIFE altering the reason the pads seem to wear out faster is because the pads have a better bite to the rotor. that extra bite is because, its gripping straight rotors and not a combo rotor/gases oh by the way, dlon't try slicks in the rain and especially not in the snow, trust me on this one |
#4 | |
調整器
they also cut down on brake dust...
*Beware when buying drilled and slotted rotors* have a greater chance of buying warped or structurally compromised rotors b/c most are done aftermarket and then resold...and BREMBO never made drilled AND slotted rotors...so cautious if and when you buy
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
#5 | ||
The Red Baron
However, slotting is effective and will increase the initial bite when you stab on the brakes and as a result will chew up pads faster. |
#6 | |
it could be that i am confused but i use slotted/vented rotors in my cars
i know from experience that that problem has happened to me in both my 92 camaro and my 95 del sol. it was worse in my camaro, so i switched to slotted. also the pads makes a huge difference |
#7 | |
The Red Baron
Are you sure it was outgassing? It could have been brake fade.
#8 | |
yeah, quite sure it wasn't brake fade, cuz with brake fade my pedal would go to the floor, it was not the case here
i got pressure, it just wasn't stopping, maybe it was something else and i'm misdiagnosing the problem but since switching, i've haven't had that problem |
#9 | |
![]() Join Date: Jul 2006
Cutting thin slots across the face of the rotor can help to clean the face of the brake pads, helping to reduce the ‘glazing’ often found during high-speed use which can lower the coefficient of friction.
#10 | ||
The Red Baron
#11 | ||
#12 | ||
![]() Join Date: Nov 2001
The biggest downside with the stock brakes on most cars is the lack of cooling. Add brake cooling intakes on the car, provide these with "hoses" that feed the air to the center of the disc. Then replace the stock brake fluid with a fluid with a high wet and dry boiling point. Replace the pads with suitable "performance" or racing pads (higher coefficient of friction at higher temperatures). Then most heat problems should be gone. The rotors can be painted on the side with temperature indicating paint, that makes it simpler to pick out the correct typ of pad and size on the cooling air intakes. In most cases the stock brakes can provide enough torque to lock up the wheels, so better "bite" is usually not needed. Don't use rotors that are bigger than you need, it's just uneccesary weight. |
#13 | ||
調整器
#14 | ||
The advantage with ceramic brakes are their low weight (the also last longer), if you fit bigger discs than needed you will decrease their advantage. Take a look at F1 for example (which use not ceramic but carbon/carbon composite discs and pads), they always go with a lighter disc if the track allows it. They also use air intakes for the brakes which are as small as possible. |
#15 | ||
The Red Baron
