Go Back   Automotive Forums .com Car Chat > Honda > Del Sol
Old 07-03-2006, 08:47 PM   #1
DESMONE
need info on b18b1 into 94 del sol s
I got me a B18B1 for my 94 del sol s. Right now it's still in the donor car, which is a '94 integra. What parts do I need beyond the actual long block? mounts, trans, ecu, harness, or whatever. Both cars are standard trans. If its not a bolt in, plug in kind of deal, what do I need to do? Thanks in advance for help.
DESMONE is offline   Reply With Quote
Old 07-03-2006, 09:42 PM   #2
AudioGuy93DelSol
NA is Best!
AudioGuy93DelSol's Avatar
Send a message via AIM to AudioGuy93DelSol
Re: need info on b18b1 into 94 del sol s
Shift linkage and axles.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
AudioGuy93DelSol is offline   Reply With Quote
Old 07-04-2006, 07:58 AM   #3
94SolGrl
Honda GODDESS/Global Mod
94SolGrl's Avatar
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
close audio guy...
you need del Sol VTEC shift linkage, a del Sol VTEC (P54) A/C bracket, mounts, wiring harness, ECU, axles, and patience. and yes, you do need the entire motor and transmission as well.
As far as the two del Sol VTEC model parts that i mentioned right out of the gate, those are NOT OPTIONAL. Those are two parts that were designed by Honda specifically so that a B series motor could fit in the slightly shorter than the civic and integra frame of the del Sol. You can get away with not having the bracket if you don't have A/C, but the shift linkages are necessary. And don't buy the Hasport ones. Save your money and get the del Sol ones from www.hondaautomotiveparts.com (I suggest picking up the A/C bracket while you're at it.)
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
94SolGrl is offline   Reply With Quote
Old 07-04-2006, 10:36 AM   #4
DESMONE
Thanks, I kinda figured. Do you Know of any books or websites that have a walkthrough?
Old 07-04-2006, 11:15 AM   #5
94SolGrl
94SolGrl's Avatar
get a Helms manual. It's the dealer service manual... walks you through pulling your entire car apart and putting it back together. or check www.honda-tech.com and see what you can find
~*Emily*~
HOW TO POST PICS!
