Go Back   Automotive Forums .com Car Chat > Cadillac > STS and STS-V
Old 05-21-2006, 01:18 PM   #1
caddyguy23
Angry front strut noise
had a thud and dealer suggested replacing front struts....his price was ridiculous so I went to a passive strut from Florida.
Noise has diminished but still getting a hard metalic clunk.
Anyone had a problem with engine mounts that might be the culprit.
caddyguy23 is offline   Reply With Quote
Old 05-21-2006, 01:29 PM   #2
maxwedge
A990 racer
Lightbulb Re: front strut noise
Are you sure it is coming from the strut area, how did the strut mounts look when the struts were replaced, they can have the symptoms you describe.
maxwedge is offline   Reply With Quote
Old 05-21-2006, 09:51 PM   #3
caddydaddy
The sway bar end links also are known to be a cause of noise.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
caddydaddy is offline   Reply With Quote
Old 05-22-2006, 07:12 AM   #4
caddyguy23
in reply: I didn't see the mounts when they were replaced but will have a mechanic check tomorrow.
Are the mounts you refer to located at the top or bottom of the strut.
As to the sway bar ends, do you mean the bushings or something else.
I'm not very knowledgeable about suspension stuff.
Thanks for your input.
Old 10-11-2006, 09:43 AM   #5
richwny
Sound to me like the dealer took you for a ride. The electronic shocks are like any other shock . If they are not leaking or still rebound properly they did not need to be replaced. I would bet that the mounts were bad and not replaced.
when the shocks were installed. Now you will pay twice
richwny is offline   Reply With Quote
Old 10-11-2006, 11:05 AM   #6
caddyguy23
Can you describe the mounts. Top and bottom or what.
Seems to me it's possible that having replaced the mounts in the first place may have solved the problem without buying new struts......Eh
Old 10-11-2006, 12:09 PM   #7
richwny
They are in the strut tower top mounted - you can view what they look like , by going to any parts site, Auto Zone, Advance Auto etc. type in the year , mfg, model and key word -- strunt mounts.Unfortunatly for you , you will pay for the struts to be removed and replaced a second time along with a wheel alignment.
Let me know how you make out. Good luck. Rich
Old 10-13-2006, 08:12 PM   #8
rhandwor
I have had struts make a noise. Their was piston slop and if you pushed on the strut sideways they clanked.
rhandwor is offline   Reply With Quote
