Go Back   Automotive Forums .com Car Chat > Oldsmobile > Ninety Eight
Old 05-16-2006, 05:43 PM   #1
sportfanjh
Dash Malfunctioning!
The dash in my 1991 oldsmobile 98 is flashing false warning signs, sometimes it switches to km/hr and you can't change it back. Any idea how to fix this or what could be wrong?!?!
sportfanjh is offline   Reply With Quote
Old 05-16-2006, 07:44 PM   #2
Alibi
Alibi's Avatar
Send a message via Yahoo to Alibi
Re: Dash Malfunctioning!
I'd guess your ECM (engine control module) or "brain" is going south.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Alibi is offline   Reply With Quote
Old 05-16-2006, 08:54 PM   #3
sportfanjh
i've tried replacing the ECM, that wasn't the problem..
Old 08-11-2006, 05:42 PM   #4
nrages
My dash always malfunctions, but not like you are describing. The odometer goes crazy sometimes. Sometimes I can read it, sometimes I can't.
So, what is the ECM, and what does that entail to replace? Is that expensive?
Thanks
nrages is offline   Reply With Quote
Old 08-12-2006, 08:35 PM   #5
Alibi
Alibi's Avatar
The ECM is the "engine control module" and it controls all the electonics in the car (aka the "brain"). A reman'ed ECM is around $50 offa Ebay and it is located behind the passenger side hush panel under the glovebox.
If the ECM isn't the cause, then I would say that the connections to the dash need to be cleaned, or the dash cluster itself is going bad. That or the sensors sending information to the dash are faulty.
-Eric
Old 09-14-2006, 07:12 PM   #6
nrages
I bought an ECM off Ebay for $40! Thanks for that idea!
However, I guess we need it reset for our car or something like that. Do I have to take it to a dealer to get this done? Or is this something we can do ourselves?
Thanks!
Old 09-14-2006, 11:58 PM   #7
Alibi
Alibi's Avatar
No, you dno't need to reset it or anything. Assuming the ECM you got has the correct PROM chip in it, all you have to do is swap them out.
-Eric
Old 09-16-2006, 08:00 PM   #8
nrages
We've already tried swapping them, and the screen tells us the "Please clean Key, Try again in 3 minutes" Can I swap PROM cards? Or what can I do?
Thank you!
