| Latest | 0 Rplys |
05-15-2006, 11:52 AM | #1 | |
No reverse lights or side markers
When I put it in reverse my brake lights work but the reverse lights don't come on. also the front side markers don't work. What do you all suggest I check? I was thinking to check the bulbs but is there a fuse that could have blown? Thanks.
At 3.15 a gallon for gas I figured it was the perfect time to buy a 4x4 truck. |
05-16-2006, 02:36 AM | #2 | |
AF - Advisor
Re: No reverse lights or side markers
Do the tail lights work?
Use a test light to check all the fuses Check the sockets for corrosion Use a test light to see if you have power at the sockets If yes, check ground connection If good, replace the bulbs If you are getting no power at the sockets and the fuses are good, then start at the switches and check to see if power is going in and coming out. Use a wiring diagram as a road map to help trace the circuits. |
05-17-2006, 04:22 AM | #3 | |
AF - Advisor
If you have the towing module disconnect it and retest.
05-18-2006, 02:43 PM | #4 | |
The brake lights work, I pulled on of the bulbs and it looked good. I checked the sockes for resistance with a voltometer and got .005 ohms, it was the same reading with the key on in reverse as it was with the key off. So do you think I should start checking switches?
05-19-2006, 06:04 AM | #5 | ||
AF - Advisor
Just check for proper voltages and replace the bulbs. Good luck |
