Go Back   Automotive Forums .com Car Chat > Ford > General Discussion
Old 03-18-2006, 11:37 AM   #1
AgnosticFront
AgnosticFront's Avatar
Exclamation Starts but then stalls instantly ???
Hey guys, I just bought a 96 ford contour @ police auction. When I first tried to start it, all it did was click... so I tried jumping it - didn’t work. Had the battery checked - was good.
So I replaced that damn starter
Now it starts. But then it stalls.
It kind of makes a high pitched noise when it turns over and it dies instantly.
IF I hold down the gas petal when I start it, it stays on for only as long as I hold the gas petal down. then it dies. When I do this, it like revs up and down while I’m holding the gas petal at a constant rate. The throttle plate moves erratically...
PLEASE HELP!
AgnosticFront is offline   Reply With Quote
Old 04-10-2006, 01:50 PM   #2
Meredith05
Re: Starts but then stalls instantly ???
I have the same problem in a 92 Tempo. Please help!
Meredith05 is offline   Reply With Quote
Old 05-01-2006, 07:55 PM   #3
Truck
Try fuel treatment, and maybe check the emissions system. Could be a clogged cat or bad gas.
Truck is offline   Reply With Quote
Old 05-01-2006, 07:56 PM   #4
Truck
Try fuel treatment, and maybe check the emissions system. Could be a clogged cat or bad gas. Maybe even a blown head. Check the oil and see if it's a good black, or a bad brown/grey....
Old 05-01-2006, 11:34 PM   #5
brokenantimatter
You are probably looking at either a vaccum leak (very common) or an emissions problem.
brokenantimatter is offline   Reply With Quote
