| Latest | 0 Rplys |
02-20-2006, 06:45 PM | #1 | |
98 Riv steering
Can anyone help with a steering problem?My 98 riv sometimes will make noise and feel stiff when you turn[mainly at slow speeds left or right]My 95 steers just fine.Thanks for the help.
02-20-2006, 09:38 PM | #2 | |
Re: 98 Riv steering
did you check the level of your power steering fluid?
1976 Chrysler Cordoba. 6.6 Liter- Lowrider 1997 Buick Riviera 3.8 L Supercharged- Cruiser |
02-22-2006, 08:53 PM | #3 | |
Re: 98 Riv steering
Mine does this occaisionally as well, mostly when you are turning while sitting still. Like if your parallel parking. Fluid level checks fine in mine. If you turn slower it doesn't do it usually.
I'm wondering if there is something going out in the steering mechanism itself? I haven't really checked into it yet. I did have one person I called about a Riv when searching to buy that said they had to spend over $800 repairing their steering. Not sure what went bad though...
~Dave~ '08 Chevy HHR SS, Victory Red, 5 spd. 2.0L Turbo, 52K mi. '98 Buick Riviera, Black, 3.8L Super-Charged, 228K mi. '98 Chevy Tahoe LT, 5.7 Vortec, Black 241K mi. '70 Pontiac Firebird Formula 400, 4spd 200k+ mi., in process restoration '10 Dodge Grand Caravan SE, 11K mi. |
02-23-2006, 06:00 AM | #4 | |
Re: 98 Riv steering
There's a service bulliten out dealing with this situation. Basically, the return line hose is undersized and restricts fluid flow causing a chattering effect in the steering while turning. It's not a safety issue and does not 'have' to be fixed but can be with larger lines. There are larger lines available to do so apparently.
Our 99 did the same thing when we first got it (used) but chose not to change the lines. |
02-24-2006, 07:35 PM | #5 | |
Re: 98 Riv steering
Wow, hadn't heard of that before. Thanks for the info! I probably won't replace mine either, unless they start leaking or something...
02-24-2006, 10:09 PM | #6 | |
Re: 98 Riv steering
Here's the applicable service Bulletin.
Document ID # 777322 1998 Buick Riviera Steering Vibration/SHudder During Parking Manuever (Install Power Strg Pressure Hose Assm) #99-02-32-007A Steering Vibration/Shudder/Moan During Parking Maneuvers on Dry Pavement (Install Power Steering Pressure (Inlet) and/or Return (Outlet) Hose Assembly) 1995-99 Buick Riviera 1997-2001 Buick Park Avenue, Ultra 2000-2001 Buick LeSabre 2000-2001 Pontiac Bonneville This bulletin is being revised to add the 2001 model year and to update the parts information. Please discard Corporate Bulletin Number 99-02-32-007 (Section 2 -- Steering) Condition Some customers may comment on a steering vibration, shudder or moan noise when steering during parking maneuvers on dry pavement. Correction Install a new power steering pressure (inlet) hose assembly on the following vehicles: 1995-98 Buick Riviera 1997-98 Buick Park Avenue and Ultra Install a new power steering pressure (inlet) and return (outlet) hose assembly on the following vehicles: 1999 Buick Riviera 1999-2001 Buick Park Avenue and Ultra 2000-2001 Buick LeSabre 2000-2001 Pontiac Bonneville Diagnosis Important In diagnosing the above listed vehicles, do not overlook other obvious repairs prior to replacing the hose(s). Verify that the power steering pump reservoir is full. If fluid level is low, fill and check for leaks. If power steering system has air in the system, perform the "Bleeding Air from Power Steering System" procedure as described in the Power Steering System sub-section of the Service Manual. Important When performing the "Bleeding Air from Power Steering System" procedure, it is important that the front of the vehicle is supported by the lower control arms. If the vehicle is not supported by the lower control arms, the procedure may cause the strut bushing to dislocate and cause new concern. Verify that the accessory drive belt is in good condition and that the pulleys are not bent or damaged. Verify proper belt tension and operation of the belt tensioner. Check for power steering hose ground out conditions. Check for good engine idle and correct engine RPM. Check to see that the rear transaxle mount does not have a plastic assembly aid installed which is used for assembly purposes. If the assembly aid is installed, remove the assembly aid and install the rear transaxle mount. With the vehicle on dry pavement, maneuver the vehicle in parking positions. If the steering vibrates/shudders or moans in this test, replace the power steering pressure hose and/or the harmonic balancer. Important A defective harmonic balancer on the 1995 Buick Riviera can influence steering vibrations after power steering hose installation. Important When installing the pressure hose on the 1995 Buick Riviera, pull down on the pressure hose at the rear of the engine or bend the hose to allow clearance between the hose and the front of the dash.
95 Saturn SL2 99 Riviera Silver Arrow 102/200 03 Silverado Ext Cab 4x4 |
02-26-2006, 10:22 PM | #7 | |
Re: 98 Riv steering
also you may want to make sure the return line isnt kinked anywhere
06 sierra denali 6.0 max 66 grand prix 389 00 caddy escalade 5.7 95 riviera supercharged 3800 85 park avenue 3.8 86 trans am 5.0 tpi |
05-10-2006, 12:17 PM | #8 | |
Re: 98 Riv steering
Thanks everyone, I am so glad I read this. My car has a really bad shudder on dry pavement. i have replaced both front hubs, and was headed in the direction of new CV shafts.......I have a 98 and have had all the typical problems with it...but didn't know about this one....
05-11-2006, 11:44 PM | #9 | |
Re: 98 Riv steering
The biggest complaint I have with my 97 Riv has been the steering shudder during low speed parking. Replaced the pump, replaced pressure hose with the redesigned GM one (Tech Bulletin). Nothing so far eliminated it. However, 2 things have recently seemed to help minimise the problem. I've been greasing the front ball joints and tie rod ends every 500 miles and I bent the metal return line down slightly where it loops up behind the radiator. Ball joint/tie rod chatter all this time???
There is certainly a design problem with the steering on these cars! Let this serve as an example of why GM's market share is in a death spiral and Japan inc is eating their lunch. Go to the NTSB web site and take a look at all the steering safety complaints for our cars. |
07-04-2007, 04:47 PM | #10 | |
Re: 98 Riv steering
I have to change the water pump on my 1995 riviera are there any diagrams for where the power steering pump bolt is. This is a supercharged model and this is giving me problems. Have a book but it is very vague.
07-05-2007, 09:28 AM | #11 | ||
Re: 98 Riv steering
Welcome to AF. Sorry but please check the date and do not resurrect old threads. Start a new post/thread addressing your issue. Thread closed.
