Go Back   Automotive Forums .com Car Chat > Racing > Technical
Technical Discuss different strategies and theories of the racing aspect.
Old 12-21-2005, 02:28 PM   #1
Ted_Mecheng
Question Rear Brakes
Hi everyone,
I've got a small technical question for you. Can anyone tell me how much cable movement at the caliper is required to engage the rear brakes when parking? I've emailed a number of companies but as of yet I have not been able to get any answers. Any help would be appreciated as it would aid in developing my university project.
Cheers
Ted_Mecheng is offline   Reply With Quote
Old 03-08-2006, 08:44 PM   #2
doock87
doock87's Avatar
Send a message via AIM to doock87
Re: Rear Brakes
parking brakes are usually drum-in-disk style. they use a mechanical system to lock up.
as for seeing how much the cable moves, i'm sure you're a smart guy. take off your center console, and measure how much your cable moves. you know how to use a ruler, right?
car manufacturer's won't really give you any answers, either. try asking mechanics and the like.
taaaaaaaaaaaaaaaaaaaaaaaaaaaaaaste....
doock87 is offline   Reply With Quote
Old 07-10-2008, 02:49 AM   #3
chevy2808
Exclamation Re: Rear Brakes
ive done many a brake job and a properly adjusted e-brake cable will only move approximately 3/4 to 1 1/4 inch
chevy2808 is offline   Reply With Quote
Old 05-18-2010, 12:24 AM   #4
Wil C
Re: Rear Brakes
depends on your car really. What kind of car? year.
Wil C is offline   Reply With Quote
Old 05-18-2010, 09:56 AM   #5
ricebike
Re: Rear Brakes
usually, the cable shouldn't be adjusted if your brake lining is sufficient...
year make model would help immensely so we can know if your vehicle has:
rear drum brakes
rear disc brakes with integrated parking brake mechanism
or rear disc brakes with internal brake shoes inside the rotor hat...
for example, i had a nissan 240sx with the second option... well my rear pads was worn and it wouldn't hold the vehicle in a parked position (i have a stick shift car)
that's the first thing to check before fiddling with your parking brake cable
ricebike is offline   Reply With Quote
