Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 09-15-2005, 10:45 AM   #1
ck101
98 windstar door adjared lights & beeps
hi, my 98 windstar has all the problems too! but i think i can help track down the "BAD" door adjar sensor that keeps the lights on. start the van, (then it happens, the lights comes on and you here 3 or 4 beeps) with all the doors shut and somebody inside, go around and open and close each door one at a time. each door working proper will beep, the door you open that doesn't make the beep sound is the door with the faulty sensor. (because it thinks the door is already open). i think the sensors cost around $20.00 to $30.00 each depending on which one.
i hope this helps, good luck!!!
ck101 is offline   Reply With Quote
Old 09-27-2005, 05:22 PM   #2
renob0214
Re: 98 windstar door adjared lights & beeps
Once you determine wich door has the faulty sensor simply unplug the sensor and spray it generously with silicone plug the sensor back in and it should work. Thats what i did and now everything works fine.
renob0214 is offline   Reply With Quote
Old 11-07-2005, 06:53 PM   #3
pebblemom
Re: Re: 98 windstar door adjared lights & beeps
How do you take the door apart to find the sensor to clean it??
pebblemom is offline   Reply With Quote
Old 11-07-2005, 10:58 PM   #4
LeSabre97mint
LeSabre97mint's Avatar
Re: Re: Re: 98 windstar door adjared lights & beeps
Door pannels are held on by both screws and plastic button darts. Get a tool that is to remove the darts. Becareful not to break the pannel. If you really want your job to last, remove the latch and clean it with a good solvent and then relube it with a good spray lub.
Regards
Dan
LeSabre97mint is offline   Reply With Quote
