| Latest | 0 Rplys |
#1 | |
rpm surging at idle
i cant seem to figure this one out. the rpm's bounce around at idle from 500 to 1200 rpm. this is an intermittent issue and i cant seem to find a pattern. also the car will die every now and then when i slow down kinda fast. any idea what causes this?
#2 | |
Re: rpm surging at idle
I'd say you're loosing pressure in your fuel system, that's why you have the surging idle and the stalling under hard braking. Have your pressure checked to see if it is at least 40 lb. psi. Possible causes, a weak fuel pressure regulator, leaking injector, kink in your line(s), etc.
Daily Overhauls Do Get Expensive Dangerous On Days Gears Engage Dead On Day Guarantee Expires Dead Or Dying Gas Eater Department Of Defense Garbage Equipment Dodge Owners Don't Get Excited Don't Overdrive Gutless Engine Drips Oil Drops Grease Everywhere 1995 Dodge Dakota SLT 3.9 V6 1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4 |
