| Latest | 0 Rplys |
08-01-2005, 04:09 PM | #1 | |
vacuum line help!
want to install a vacuum gauge on my 99 windstar, 3.8L,but i cant found any vaumm line.anyone here know where is vacuum line locate at 3.8l engeine?
thank you |
08-01-2005, 04:58 PM | #2 | |
Re: vacuum line help!
Hi
the accessory vacuum lines come off of the back of the intake manifold. They are colored semi-rigid lines. Or there is the brake master cylinder vacuum. Do you want to put in a permanent gauge or measure vacuum? |
08-01-2005, 08:42 PM | #3 | |
i m going to install a permanent gauge ,the vacuum line is locate at left side or right side? can you show me ,thanks alot
08-01-2005, 11:17 PM | #4 | |
Hi
as my machine is a little different (96)I can't say I immediately can identify a vacuum line from your picture. Does your gauge come with any directions? Does it say to "splice" into and existing vacuum source? I suppose you could put it in line in the PCV line between the PCV valve and the intake. Anyone want to jump in here? I have not installed a vacuum gauge, just measured vacuum a time or two. |
08-01-2005, 11:48 PM | #5 | |
The vaccum system is ALWAYS drawn off of the intake side of an engine. Follow that 1/2" hose coming from the can behind your brakes master cylinder to the intake manifold, for a likely spot to tie into.
Sorry, I may be a bit naieve, but why do you need a permanent vaccuum gauge? I thought this was a "turbocharger" type necessity. Karl |
