Go Back   Automotive Forums .com Car Chat > Chevrolet > Corsica
Old 07-29-2005, 11:57 PM   #1
morgan 55
91 corsica engine cuts out
91 Corsica, 3.1. Starts fine, runs great but after it reaches operating temp about 15 minutes the engine cuts out. I have to wait about 25 minutes before it starts again. Car is not overheating.
morgan 55 is offline   Reply With Quote
Old 07-30-2005, 11:12 AM   #2
jsgold
Possible crank sensor failure, or ignition module may be dying. Both are responsible for firing on your engine and when failing will act up when warm. Test for fire when engine stalls. The crank sensor is pretty cheap to try first. You can remove the ignition module (sits under your coils) and have it tested at almost any parts store such as NAPA or Advance etc. You will have to remove the coils and module together. The module is very thin and is connected to the coils.
I used to be indecisive, now I am not so sure.
jsgold is offline   Reply With Quote
Old 08-03-2005, 05:36 PM   #3
morgan 55
Re: 91 corsica engine cuts out
Thanks jsgold. 91 Corsica cut out problem was crank position sensor. Car is running great. Morgan 55
