| Latest | 0 Rplys |
07-09-2005, 08:59 AM | #1 | |
97 LTC, clicking noise behind dash
1997 LTC, Signature Series. After the car is started there is a clicking sound coming from behind the center of the dash board, it tends to be intermittent. Changing the setting on either the air condition, heat, fan setting does not change the tempo or stop the clicking. Recently on two occasions, A/C on while clicking noise is occurring the heat came on. In order to return to A/C, turn of climate control system and turn A/C back on.I hope someone can help me solve this problem.
07-11-2005, 01:35 PM | #2 | ||
Re: 97 LTC, clicking noise behind dash
Sounds like the blend door actuator (behind & above the glovebox) is beginning to fail. The clicking (inside the actuator) will eventually lead to a broken actuator, then the blend door will flap around (bang, bang, bang...) making a door slamming sound. Replacing this little engineering gem is a nightmare therefore, labor expensive. The little actuator is relatively cheap. Do some searches on Town Car, Blend Door, Actuator for more information. Theres several posts here, and elsewhere. Also, there many writeups on doing the job yourself, but it is labor intensive, easier done with two people, and requires dash panels removal to gain access to the actuator.
-Steven 1996 Town Car, Cartier |
07-12-2005, 11:33 AM | #3 | |
blender acuator -Towncar !
I have the same problem for a long time. The clicking and knocking same began, then I lost any cool air coming through from AC and traced it to a door failing to operate controlled by the acueator. So i finally found some instructions to pull the Dash and save $ 500 labor. I pulled the dash, dropping the Steering column and all-not bad w/ instructions.
I changed the acuetor ($72), put the dash back together and still only Hot Air is blowing out. The door is working. Im dropping off the TCar today to have them check the 134a AC gas. Id be surprised if it is low on gas b/c the AC was working prior to the knocking noise. Its been over a year since it malfunctioned. Things i learned: There is a vent trap door behind the glove box, but I dont think this is the one that is causing the problem. Most analytic trouble shooting point towards the blender door acueator operating a door located directly behind the middle of the dash (clicking noise),. U can actually see this door operating by peering through two sets (thru the right side of the radio) vents way back in there. Anyway, i still have plenty of hot air blowing, took some extra pictures and have a website to get instructions to pulling the dash if anyone needs them. ...........HELP--IDEAS--Still "No Cold AC air " !????? |
07-12-2005, 01:05 PM | #4 | ||
Re: blender acuator -Towncar !
I'd be nice if you did post a link to your web site.. BTW The blend door actuator is behind/above the glove box, not in the center of the dash. You can't see it operating thru the vents as it sits atop the Air Plenum Chamber. This one actually blends hot/cool air so it may be the one you still need to fix. The blend door in the center directs floorvent/dashvent air flow. Here's one writeup from Sweden that helps a bit: http://www.lincolnsonline.com/article20.html
07-13-2005, 12:10 AM | #5 | ||
Re: Re: blender acuator -Towncar !
Ill send addy to the dash bolts later. |
07-13-2005, 01:50 AM | #6 | ||
Re: Re: Re: blender acuator -Towncar !
I havn't had the pleasure of doing this job yet myself, but I've read just about everything printed on the subject 'cause mine's going to break too. Anyway, I have some pages from the Service Manual posted on the www with diagrams and part numbers, and I'll also post links to some very good references and pictures. On my webpage look for the pdf links to "1996 AC Blend Door...". Here's some others: (not lincoln specific, great shots) http://www.shoforum.com/showthread.php?t=31156 and one tip: http://www.lincolnsonline.com/cgi-bi...c&f=3&t=004625
07-14-2005, 10:16 AM | #7 | ||
Re: Re: Re: Re: blender acuator -Towncar !
07-14-2005, 03:00 PM | #8 | ||
Re: Re: Re: Re: Re: blender acuator -Towncar !
Google 19E616 Here's another possibility to consider: Ford PN E3VY-19C734-A or YH-409 in Motorcraft Mark VIII article on Preventing Actuator failure: Reinforce with wire wrap and Epoxy More: More Mark VIII Info Stab at the Part Number ? Stab at the Part Number ?
08-11-2016, 11:47 AM | #9 | |
Under drivers dash fuze box Unplug 15a Fuze # 1 turn on key see if clicking goes away Plug Fuze back in if clicking stops run self test If it comes back removed fuze and install a 5/8 shut off valve in the upper heater hose turn it off to have AC on for Heat not great but is a cheap fix. will work on 95 to 97 Lin TC
The System will work without this fuze is power for the Blend door only the blend door is spring loaded to the full heat pos. at least you wont have to hear that click clack cluck. Buzzy |
08-16-2016, 06:50 PM | #10 | |
shut off the engine side (pressure) or upper on some town cars Heater Hose
Buzzy |
