Go Back   Automotive Forums .com Car Chat > GMC > Sonoma | S-15
Old 07-06-2005, 06:13 PM   #1
batman19
Send a message via AIM to batman19
brake problem, pls help
my brake is making the high pitch nose, even after i changed the rotor and pad.
it usually makes that high pitch nose when the wheel is slowing down right b4 come to competely stop.
i have no idea what make that nose, can someone pls help?
1997 Civic HX
1.6 D16Y5 engine
Auto with 55K
STOCK
batman19 is offline   Reply With Quote
Old 07-06-2005, 07:58 PM   #2
rlith
rlith's Avatar
Send a message via AIM to rlith Send a message via MSN to rlith
Re: brake problem, pls help
More than likely the hub bearing at this point. Did you also put anti squeal on the back of the pads?
rlith is offline   Reply With Quote
Old 07-08-2005, 06:12 PM   #3
batman19
hub bearing? what are u talking about?
where should i add the anti squeal on?
1997 Civic HX
1.6 D16Y5 engine
Auto with 55K
STOCK
Old 07-08-2005, 09:57 PM   #4
JimmySLS
JimmySLS's Avatar
You put the anti squeal on the back of the pads.(the metal part) It stops the brakes from squealing and quiets them down.You can buy it at Autozone for 99 cents.Try the anti squeal first to see if that works if not,I would replace the wheel hub.
JimmySLS is offline   Reply With Quote
