| Latest | 0 Rplys |
06-08-2005, 02:18 PM | #1 | |
check engine light on and O/D off light blinking
I am a woman with 2 small kids, and I have a 99 kia sephia and the check engine light came on yesterday and at the same time the O/D off light started blinking. I took the car to my local autozone and they read the trouble codes which were:1624(anti-theft system) which i didn't even know i had, and 0740(the torque converter engagement or circuit malfunction.) I called kia but trhe said i'd have to bring the car in which I live 2 hrs away from them. Does anyone know what is going on or what to replace?
Marlo |
06-09-2005, 01:05 AM | #2 | |
Re: check engine light on and O/D off light blinking
Could be as simple as low fluid or an air leak... The only way to tell will be to have someone take a look. Jiffy lube will usually check fluid level for you for free... and they can tell you if the fluid looks bad as well. If the fluid level checks fine, my opinion is you will need to take it to a mechanic. Well, two mechanics at least..
I'm not a mechanic, I'm the guy people bring their car too when they don't run. I usually scratch my head and tap on stuff, then call the dealer to see if they can help me find the carburetor. |
06-12-2005, 11:08 AM | #3 | ||
Re: Re: check engine light on and O/D off light blinking
06-12-2005, 11:20 AM | #4 | |
kia's don't use 1624 anti-theft codes p1624 is mil request which means your trans computer wants you to look at it. in simple words
06-12-2005, 11:34 AM | #5 | ||
06-13-2005, 12:23 AM | #6 | |
it wanted u to look at the other codes like the 0740 you got there I sent you a pm on all this
06-13-2005, 01:09 PM | #7 | |
I never received the PM.
06-13-2005, 09:40 PM | #8 | |
not sure if you are the same person at the kia forum but if your not then here it is. very sadly "you might need a transmission"
06-13-2005, 10:30 PM | #9 | ||
06-18-2005, 07:53 PM | #10 | |
I have a 2000 Sephia, and mine does the same thing, I find that when it does this its low on oil. I put more oil in it and drive it, and not long after the lights go out.
Tasha |
01-04-2006, 11:39 AM | #11 | |
Hey I am writing about your overdrive light and check engine light. My 99 Sephia did the same thing but I got the codes P1624 and P0732 and I had the gears in my transmission fixed over two years ago. The codes just popped up for no reason and stayed on for a few days and then went off by themselves. Did you have any more problems? If not I think whoever told you that they give false readings was right. I have a son too and I can't afford to run to the dealer to fix things. I am going to get rid of this car as soon as I can afford to.
If you have had any more problems or have any advice please let me know. |
01-04-2006, 11:40 AM | #12 | |
Hey I am writing about your overdrive light and check engine light. My 99 Sephia did the same thing but I got the codes P1624 and P0732 and I had the gears in my transmission fixed way before the lights came on, over two years ago. The codes just popped up for no reason and stayed on for a few days and then went off by themselves. Did you have any more problems? If not I think whoever told you that they give false readings was right. I have a son too and I can't afford to run to the dealer to fix things. I am going to get rid of this car as soon as I can afford to.
01-04-2006, 01:51 PM | #13 | ||
The problem is electrical and usually caused by ground problems. If the repairs are not made to fix the grounds, usually the trans. ends up failing. There are several grounds on the vehicle that need to be cleaned and or updated but would not be easy to explain how to do this on this forum. This is what I would do. Go to the dealer and have them update the grounds per Kias bulletin. If that does not fix it the damage is usually done and the trans needs to be replaced. |
01-05-2006, 03:43 PM | #14 | ||
I'm sorry you are having problems with your car I know how that goes. Well, for starters, I've never had any work done to my tranny. I disconnected my battery, then reconnected it. The light never came on again, but before I did that I changed my spark plugs and found that they had alot of oil on them. I then researched to find out what caused that and was told to change my valve cover gasket. which I ordered online at www.kiaparts.com. I replaced the valve cover gasket which is so easy you can do yourself. That stopped the oil from leaking into my spark plug wells. I also cahnged my air filter, another one you can do yourself. after doing all of that I haven't had any problems and have put another 40000 miles on it since then. all that had happened was with the oil being on my spark plugs sent false readings to my computer. Just check those spark plugs and see if there is oil on them and then go from there. By the way, the valve cover gasket is really cheap. Let me know if you need anything else. I've done a ton of research on this car.
01-05-2006, 03:47 PM | #15 | ||
change your valve cover gasket, and that should correct your problem with losing oil. You are probably losing it into your spark plug wells.
