Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 05-09-2005, 05:29 PM   #1
Speedy_1234
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Question 96 Turns on but when gas pedal is press it wont accelrate
I have a 96 Lumina when I turn on the car it turns fine but when I give it gas the car starts to like turn off it self when I am in the street and I have the pedal to the floor it does not accelrate as fast it should it goes like 20 miles and it takes about 7to ten blocks so the car can go form 20miles to 40 or 50 miles
opcorn:
Speedy_1234 is offline   Reply With Quote
Old 05-09-2005, 08:56 PM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: 96 Turns on but when gas pedal is press it wont accelrate
Start by replacing the fuel filter, see what happens.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 05-10-2005, 09:44 PM   #3
tblake
In God We Trust
tblake's Avatar
is your cat converter plugged?
tblake is offline   Reply With Quote
Old 05-11-2005, 07:49 AM   #4
jeffcoslacker
Re: Re: 96 Turns on but when gas pedal is press it wont accelrate
Good question.
If you have access to a vacuum gauge, verify the the intake path is clear of resrictions or bad air filter, connect to manifold vacuum and warm engine to operating temp. Open throttle and prop open if possible to acheive a steady 2500-3000 engine speed. Watch the reading, it should stay steady once stabilized. If it begins to drop steadily the longer it runs, the exhaust (usually the cat) is restricted.
...empty gun rack.
