Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-12-2005, 10:25 PM   #1
82 meeno
Brake Light Problem - Need Help
My High mount brake light is the only one working... i thought the bulbs had blown but,not the case,
i triple checked the fuses and all were okay also, i replaced the brake light switch... and still nothing. The new one clicks when i hit the brakes, not sure that is all about (maybe adjustment).
What are the common places to check for burned or broken wires,wire color would also help....
When i turned my headlights on, all lights in the rear are fine, the flashers are fine, I'm convinced that my broken wire is near the bulb.....
Any help is appreciated.
Ray
82 meeno is offline   Reply With Quote
Old 04-14-2005, 07:55 AM   #2
RayQix
Send a message via AIM to RayQix Send a message via Yahoo to RayQix
Re: Brake Light Problem - Need Help
Have you run any tests using a multimeter on the brake switch wires? Otherwise, i'd check for a possible short in the ground for the lower lights/wires using the meter.
You could "Rig" something, but see what the meter sez first...
RayQix is offline   Reply With Quote
Old 04-14-2005, 08:21 AM   #3
82 meeno
Ray
Thanks,
I did find out that model yr 94-95 have there brake lights wired to the turn signal switch and they have been prone to fail. The high mount stop light is wired directly to its own circuit.
95% sure i need a new turn signal switch.
Old 04-14-2005, 09:10 AM   #4
RayQix
Get your list of stuff together for that project...steering-wheel puller, etc...
At least you'll know it's fixed once its done
Old 04-15-2005, 11:46 AM   #5
82 meeno
Re: Re: Brake Light Problem - Need Help
Thanks,
Thanks for your help..... This is probably the most responese, I've gotten from this board!!
I'll post back when done!
Old 07-23-2005, 11:01 PM   #6
dodge99
Re: Re: Re: Brake Light Problem - Need Help
i have a 94 i just got on a deal and guess what i have the same problem ... it is in the turn signal switch also, p.s. dont forget to pull the fuse on your air bag before starting.
dodge99 is offline   Reply With Quote
Old 11-25-2005, 12:10 PM   #7
dmcbeth
Thanks,
I HAVE A 96 CUTLASS THAT HAS THE SAME SYMPTOMS. THE LOWER
BRAKE LIGHTS DO NOT WORK, BUT THE 3RD LIGHT DOES. WHEN USING
THE RIGHT TURN SIGNAL THE LEFT BRAKE LIGHT SOMETIMES WORKS.
COULD THE TURN SIGNAL SWITCH BE THE PROBLEM ON A 96 ALSO??
DMCBETH
dmcbeth is offline   Reply With Quote
Old 11-29-2005, 03:30 PM   #8
Wekke
Electrical problems can be a pain to trace, but I also think you might want to measure if you're getting correct voltage coming from the turn signal switch. In an earlier reply it said that the brake lights are wired into the turn signal switch.
I had the exact same problem on my '72 Ford LTD: turn signals OK, but no brake light. It has 2 feed wires coming from the brake light switch going to the turn signal switch. One feeds left stop & rear turn, the other right stop & rear turn. (Front turn signals have their own separate contacts in the switch). If the switch fails, like on mine, this is one possible effect. But do measure out the switch before you buy a new one, 'cause it might as well be just a bad wire...
Good luck,
Wekke
94 Olds Cutlass Ciera 3.1
72 Ford LTD
Wekke is offline   Reply With Quote
Old 03-09-2011, 12:48 PM   #9
thegoodman97
I have a 94 buick regal and my brake lights do the same. the turn signals work the four ways work and park lights work but when i hit the brakes the third brake light only comes on. It used to work sometimes not it seems that it doesnt work at all. Could the turn signal switch be my problem also?
thegoodman97 is offline   Reply With Quote
Old 03-09-2011, 02:09 PM   #10
brcidd
brcidd's Avatar
Wiggle the hazard flasher switch- turn it on and off about 10 times- then try brake lights and/or turn signals- The hazard switch is least used and contacts can become non-continuous- so wear the in alittle and see if it helps. Brake lights and turn signals are fed through this switch.....
Try the above before replacing switch- it works for me most of the time...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 03-09-2011, 09:02 PM   #11
thegoodman97
the wiggling of the switch didnt work so i guess i should replace the turn signal switch huh?
