| Latest | 0 Rplys |
04-03-2005, 08:08 PM | #1 | |
bad gas milage and runs bad
I own a 94 Bonneville and ever since I owned it I have gotten bad milage. Also for about a month it has been jerking at takeoff and realy bad when accelerating at highway speeds. I took it to a dealer and they did a diognastic on it and found nothing. There is no check engine light.
I am thinking of another Bonneville 2002 or 2004 and was wondering if gas milage would be in upper 20's on highway. I own a 92 Suburban and my 94 Bonneville dosen't do much better. Any help will be appreciated. Thanks: TomW |
04-04-2005, 05:40 AM | #2 | |
Fight the powwa!!!
Re: bad gas milage and runs bad
The newer Bonny's get around mid 20's on highway from what I have heard. Also on the 94 when was the last time it had a tune up?
Welcome to AF John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
04-04-2005, 08:46 AM | #3 | |
Poor acceleration and jerking may be linked to several factors: normal maintenance like spark plugs, plug wires and coil packs....but the last would bring an error code and you know what you did about that maintenance.
Non maintenance items that come suspicious after more than 10 years are the MAF and the TPS. Those are located together and you can get them in yours hands. www.avigex.ca/xport/tpsloc.jpg www.avigex.ca/xport/maf.jpg Make sure the MAF little shiny wire in the intake throat is not covered by a coat of clay: it happened in mine after an air filter "malfunction". CLeaned with alcohol and got back to normal. ANd TPS sensor can be tested with a voltmeter (on the car) or with an ohmmeter - in your hands - for continuity of the resistance track. These tests cost NOTHING and will either clear the problem or clear the way for other tests. MAF problem may be there and not trig a code TPS problem would in most cases give an error code 21 or 22 (OBD1) or equivalent for OBD2
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
