Go Back   Automotive Forums .com Car Chat > Racing > Street Racing
Old 03-09-2005, 11:28 PM   #1
Slowprocess
Slowprocess's Avatar
Send a message via Yahoo to Slowprocess
Going to try out the new tires this weekend
Well, I got a set of Mickey Thompson ET Streets today. They're so much softer than my bfg drag radials. We're having a big meet in Greenville,MS this weekend, so I'm looking to try them out. Best 60ft on the bfgs was a 1.74, so I'm really looking to get in the 1.6s with the new tires/rear end setup.
I'll post up results and opinions on these tires Sunday.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
Slowprocess is offline   Reply With Quote
Old 03-09-2005, 11:50 PM   #2
-Jayson-
-Jayson-'s Avatar
Re: Going to try out the new tires this weekend
i cant wait, good luck
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
-Jayson- is offline   Reply With Quote
Old 03-09-2005, 11:53 PM   #3
clawhammer
clawhammer's Avatar
Do you have the N2O installed yet?
clawhammer is offline   Reply With Quote
Old 03-09-2005, 11:56 PM   #4
chevytrucks92
chevytrucks92's Avatar
Not trying to be a smartass, but why dont you just get some slicks for when you go to the track?
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
chevytrucks92 is offline   Reply With Quote
Old 03-10-2005, 12:33 AM   #5
Slowprocess
Re: Re: Going to try out the new tires this weekend
The guy that owns the track had these for a mustang, but ended up not using them, so I got them for $225. I couldn't pass up the deal on them, plus I've been having a hard time finding true slicks to fit on a stock tahoe wheel. Plus, I really want a D.O.T tire for the street class races. These require a D.O.T approved tire, and I've heard that the MT ET Streets are the best in that class.
clawhammer- Haven't got all the parts I want to use yet. I've decided to run a stand alone setup, so now I'm waiting on my 1 gal fuel cell, fuel pump, etc. I decided on this so I could run a high octane mix with the nitrous to reduce chances of detonation/pinging. I'm just being paranoid about it, but I do want the motor to last.
Old 03-10-2005, 02:53 AM   #6
-The Stig-
On Fire!
-The Stig-'s Avatar
Send a message via AIM to -The Stig-
Pansy... just rig up a house hold spray bottle nozzle in the intake stream that you can pump manually from inside the cab.
Screw all that fancy jetting shit and fuel add-ons. Be a man about it!
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
-The Stig- is offline   Reply With Quote
Old 03-10-2005, 11:02 AM   #7
chevytrucks92
Re: Re: Re: Going to try out the new tires this weekend
That is a good deal. I sure would like to find a set of 31x14 inch slicks for that!
You're probably better off sticking with DOT approved tires for now though, becuase once you go slicks, you got a little more rules to follow. For starters, any vehicle running faster then 13.99 in the 1/4 or 7.35 in the 1/8th on slicks has to have a drive shaft loop.
And when you get N02, you're going to be into the 11s, very easily, and if you get faster then 11.49 in the 1/4 or 7.49 in the 1/8th (provided you ever run at an 1/8th mile only track) then you pretty much have the same safety requirements that I have (fire extinguisher, minimum of 6-point roll bar, 5-point belts), with the exception of having to have after market axels and rentention devices, a transmission shield, a SFI 18.1 approved harmonic balancer, and a full rollcage. All of those rules would kick in if you get faster then 10.99 in the 1/4 or 6.99 in the 1/8th.
As for me, all the 1/8th and 1/4 tracks close to me are opening this weekend for test and tune, and all start racing within 2 weeks. I plan on going to some of these tracks atleast 10 times this season (my local 330 track probably won't be opening, which sucks becuase it was only about 35-45 minutes from home). In order to do so though, I have to get new seat belts (mine are out of date) and before I can race anywhere, I need new slicks. SO, probably within a couple months, I'll have some actual 1/8th times to post instead of just estimates based off of past 1/8th and 330 runs. I'm expecting to be somewhere in the high 6.60s to low 6.80s though. I'm also looking for very high 1.30 or very low 1.40 60 ft. times with new slicks and much better hooking tracks then what I usually run on.
This is funny to say, but I hope I dont get faster then 6.49 (which I'm not looking to) because that will put me in a different rules class (all of what I have to have now plus a flexplate and license--all of these rules are from an IHRA rule book for the Summit Sportsman Series, which is bracket racing and thats what all tracks run except for when there's a national event taking place).
Anyways, good luck with your runs this weekend.
**1966 Chevy II**
Old 03-10-2005, 11:17 AM   #8
JekylandHyde
AF - Advisor
JekylandHyde's Avatar
PLEASE link me to the thread of your results.
I do not want to miss it.
The MR2 community has seen a serious advantage with the MTs over the BFGs. Unfortuantely I just bought a new set of BFGs
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
JekylandHyde is offline   Reply With Quote
Old 03-14-2005, 12:59 PM   #9
Slowprocess
Here's my update on this weekend. The et streets are awesome to say the least. At our local track, the best I could ever muster up was a 12.8 on the bfgs. I got my best time to date Saturday with a 12.50@105.96mph over my previous 12.54. This may not seem to be that great, but considering the difference at that track, it is tremendous for me. I now know I can see a low 12 sec pass at Hattiesburg.
Best 60ft on the bfgs was a pathetic 2.2 on a nonexistent prepped track. Best 60ft saturday was a 1.84(still not my best to date, but a world better than the normal 2.2) I'm really anxious to go back to Hattiesburg on the mickeys, because I definately believe I can pull a 1.6 60ft there. My only complaint on these tires was that it kinda swayed alittle bit down the track sometimes(I would assume due to the sidewalls being soft and low air pressure), while the bfgs always drove like street tires down the track(really smooth).
I would also get alittle swirly past the 60ft mark sometimes(like on my 1-2 shift). I guess what little track prep they did only extended to the 60ft mark, so if it was really hard into it, it would get sideways.
I tried a 2000rpm launch as well. Truck came out unbelievably hard, but I got alittle wheel hop, killing my 60ft. On a well prepped track(such as Hattiesburg,Memphis,etc.), that run should have put me in the 12.3-12.4 range easily with a set of traction bars.
Other things I noticed. The tires were an absolute bitch to mount on the 16x8 wheels. We had a tough time getting the bead to pop out, and finally did so with an unbelievable amount of air pressure.
The mickeys are a good bit lighter than the bfgs. They also seem to warm up faster and with less effort. They also wear better than the bfgs. I'll have some vids up tonight of a few of my runs, as well as my buddies extended cab running on my old bfgs. He had no trouble hooking them, and he also bested his times Saturday. Stay tuned, and my vote now goes to the et streets over the bfg drag radials for street class track tires.
I won every race I had Saturday. I raced 5 different mustangs, 2 camaro z28s, 1 camaro ss, a diesel truck, an old muscled out looking car(didn't catch what it was), a new honda sport 4wheeler , and some trucks similar to mine(in appearance).
None of the races were very close.
Old 03-14-2005, 01:09 PM   #10
JekylandHyde
AF - Advisor
Damn ... why did I buy a new set of BFGs at the end of last season
Ugh.
Old 03-14-2005, 01:09 PM   #11
JekylandHyde
AF - Advisor
Thanks for the detailed update.
Old 03-14-2005, 01:49 PM   #12
-Josh-
Automotive love doctor
-Josh-'s Avatar
Send a message via AIM to -Josh-
Nice, good luck at the next track.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
-Josh- is offline   Reply With Quote
Old 03-14-2005, 03:16 PM   #13
street_racer_00
street_racer_00's Avatar
Slow proccess, fast truck.
2000 Nissan Maxima SE, autotragic, sterling mist
My Max: Getting smoked by boosted cars since 2004
2004 AF award winner: longest time period w/o posting an actual street racing story
Originally Posted by CassiesMan
I got to see boobiues!
street_racer_00 is offline   Reply With Quote
Old 03-14-2005, 04:02 PM   #14
Mister_Sinister
Mister_Sinister's Avatar
hyuck hyuck (corney joke man )
Anyways, great times man! Can't wait to see the times you'll get when you spray !
2001 Hyundai Tiburon - SOLD
2001 Honda S2000 - The New Hotness
Mister_Sinister is offline   Reply With Quote
Old 03-14-2005, 06:35 PM   #15
Igovert500
blue + red light magnet
Igovert500's Avatar
Very nice results, definantly get those vids up
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Igovert500 is offline   Reply With Quote
