Go Back   Automotive Forums .com Car Chat > GMC > Sonoma | S-15
Old 01-31-2005, 11:04 AM   #1
rmclellan
Anti Freeze Leak
I have a 98 Sonoma 2.2 that is leaking Anti Freeze from the Back of the engine on the drivers side. I thought is was a freeze plug that may have popped off. It looks like it is coming from a hole in the side of the engine right below the exaust manifold. I went to get a freeze plug and they wanted to sell me a metal cap. I did not get it because i did not see how that would stop a water leak. I am hoping it is not a blown head gasket. When you put water in, you can see it running out of the side of the engine. It is hard to see because of everything in the way.
Any help anyone can suggest would be greatly appreciated.
rmclellan is offline   Reply With Quote
Old 02-01-2005, 03:02 AM   #2
BlazerLT
AF -Advisor
BlazerLT's Avatar
Re: Anti Freeze Leak
Sounds like the freeze plug is leaking bro.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 03-05-2005, 12:52 AM   #3
BKFT_HOTRODER
The only way to find the true leak is if you pressure test the cooling system. a lot of freeze plugs are metal, they are a pretty tight fit
BKFT_HOTRODER is offline   Reply With Quote
Old 03-13-2005, 05:16 PM   #4
Danlorus
Head gasket
I had the same problem. Head gaskets are a common problem with these engines around 100k miles.
Danlorus is offline   Reply With Quote
Old 03-13-2005, 05:23 PM   #5
BlazerLT
AF -Advisor
BlazerLT's Avatar
Re: Head gasket
No they are not a common problem.
Old 03-13-2005, 05:39 PM   #6
Danlorus
Scene problem before
I shouldn't say common, but I have two other friends with the 4.3 vortec who both had this problem with there engine around 100k miles. Just an odd coincidence.
Old 03-20-2005, 09:53 PM   #7
95-Sonoma
I don't now about common or not but I had a antifreeze leak on my 2.2 at about 85k and it was also the head gasket. Wasn't that bad of a job to change it out. I bought a complete kit and changed all of the valve stem seals while I had it off. Took a little under a day.
Jon
95-Sonoma is offline   Reply With Quote
Old 05-10-2005, 01:16 PM   #8
TrevDog
How does one go about pressure testing their cooling system to look for a leak?
TrevDog is offline   Reply With Quote
Old 05-16-2005, 07:42 AM   #9
rlith
rlith's Avatar
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: Anti Freeze Leak
Use a pressure tester and an air compressor, run it up to 30 psi and see if there is any bleed off or any streams of coolant shooting out. The unit goes over the rad cap
rlith is offline   Reply With Quote
