| Latest | 0 Rplys |
12-19-2004, 01:59 PM | #1 | |
antifreeze leak
k guys its a cold one here in michigan 8 degrees. i hope in my 95 gt to warm her up and when i moved it i noticed antifreze on the ground...nothing huge but a decent leak was obvious. i donthink it started untill after i started it and it seems to be comming from right under the radiator. it may be the overflow resevoir but it is on the left side{when looking at the front of the car} its too cold to sit out there and mess witrh it anyone have any ideas.
95 gt vert built aode underdrive pullies slp cat back bbk o/road h nos dry 80 shot |
12-19-2004, 03:53 PM | #2 | |
Re: antifreeze leak
Might be one of the hoses check all of them and make sure the clamps are tight. When you get under the car look for the source of the leak. Worst case, you might have a slow leak from the radiator.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt. |
