Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 03-02-2002, 07:39 PM   #1
DarkImportGrey
DarkImportGrey's Avatar
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
Brakes
God dammit. All I wanted was my alignment fixed and my snow tires taken off. What I got was a 'do or die' warning. My brakes are SHOT. Total estimate for complete brake overhaul plus 90000 mile tune up: $900. Here's my problem: I knew I was going to have to replace the brakes soon, but I was going to wait until I had my new wheels on so I could fit a big brake kit on. You can't fit the big brake kits with the 13" rims still on. So I have to have a complete brake overhaul instead of buying new rims. Not to mention that if I buy a big brake kit I will be replacing like-new OEM brakes once they are overhauled. Dammit dammit dammit.
Here's some of the individual charges:
front brake overhaul: 190
front rotor set: 80
rear brake overhaul: 170
They wanted me to pay 15 bucks for a new radiator cap. Why in the world would I need a new radiator cap? Included in that 900 dollar cost is a coolant flush, radiator hose replacement, new thermostat, 4 cylinder tune up, distributor cap and rotor, air filter, and fuel filter. All that for 900 bucks including labor. Is that a fair price?
DarkImportGrey is offline   Reply With Quote
Old 03-02-2002, 08:33 PM   #2
crxlvr
Slowest Automatic Civic
crxlvr's Avatar
Send a message via AIM to crxlvr
900 doesnt seem that bad if thats including labor, for the work your getting done. as for the new cap, you can prolly get a new one yourself for half the price at any auto store, maybe your is leaking or not venting correctly.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
crxlvr is offline   Reply With Quote
Old 03-02-2002, 10:21 PM   #3
EightOhOne
EightOhOne's Avatar
good lawd, do the brakes yourself...paying that much is ridiculous IMO
what is included in thier "overhaul" anyways? they also said your brakes are shot? any noises or excessive vibrations to back this up?
as for the rest-
coolant flush-easy
new Rad. hoses-easy
thermo- duno..never had to replace
tune up-not hard(whats included in their tune up?)
air filter and fuel filter-both easy
I dunno...i wouldnt want to blow 900 bucks on that myself, but im also a cheap bastard.
hell...for 900 bucks i could almost have a new "used" b16a setup
if youre not too familiar with your car, or mechanically inclined, i suggest getting a helms manual, it will tell you everything you need to know to do just about anything
EightOhOne is offline   Reply With Quote
Old 03-03-2002, 12:15 AM   #4
DarkImportGrey
Well basically they said that the brakes would be have to be completely replaced. If that is true (I am going to take a look at the brakes myself this week) then I will just do the work myself. I think what I'll do is get some slightly used OEMs to last me until I can put my rims and big brakes on. I hate surprises.
Old 03-03-2002, 12:26 AM   #5
90CRXZCSi
90CRXZCSi's Avatar
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Just replace the rotors and brake pads and repack the bearings if they are drum in the rear.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
90CRXZCSi is offline   Reply With Quote
Old 03-03-2002, 01:42 AM   #6
SkyNex721
SkyNex721's Avatar
Send a message via AIM to SkyNex721
BTW. Changing the Thermostat is easy as hell. Since you are flushing the coolant system anyway. All you gotta do is remove the thermo. housing yank out the old one and the old gasket, Clean the area, and replace with new gasket and thermo.
R.I.P. - You shall be resurrected.
SkyNex721 is offline   Reply With Quote
Old 03-03-2002, 02:11 PM   #7
Ebranste
Send a message via ICQ to Ebranste Send a message via AIM to Ebranste
No brake system ever need a complete overhaul. You probably just need new pads/shoes or pads/pads all the way around at the worst.
If you had leaking calipers/wheel cylinders, your mechanic would have stressed that, so you're getting charged $900 for parts and labor that would most likely cost under $100 if you did it yourself.
Since you don't seem to be mechanically inclined.....definately have someone help you out or get the helm's manual......cost $75.
Either way, you save a good deal of dinero, even if you need to buy the basic tools needed to accomplish the formentioned tasks.
Ebranste is offline   Reply With Quote
Old 03-03-2002, 03:31 PM   #8
ricodemus
yeah, the thermostat is pretty easy to replace, and the part is only like 15 bucks. My uncle did mine and he thought is was weird where the placement was (on the back sid of the engine instead of front) but it's not something you really would need a mechanic to do if money is an issue.
I'm a lonely male who'll settle for any phony in a ponytail - MCPB
The b16 is in and running strong
ricodemus is offline   Reply With Quote
Old 03-03-2002, 04:05 PM   #9
PFCfutrell
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
If you lived in Georgia i'd offer to come help, none of that is stuff that you NEED a mechanic for. If you're cheap like me you'll figure out how to do brakes and cooling systems on your own REAL quick.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
PFCfutrell is offline   Reply With Quote
Old 03-03-2002, 04:12 PM   #10
Ebranste
Hell, if you can drive the Florida, I'll do all the work for ya for half the price including parts.
and just to make it seem realistic, I'll write up a receipt with a bunch of crap on it that doesn't make any sense and itemize it to death to make it seem like it was alot of work.
2002 OHV 3.0L Lack of power, stiff brake pedal Ruley73 Taurus | Taurus Wagon 7 03-05-2011 11:49 AM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 09:49 AM
The Brakes the Brakes the Brakes are on Fire!!! Neutrino Street Racing 14 04-24-2004 03:29 PM
Brakes, Brakes Brakes hondaman-iac Accord/TSX/Accord Hybrid 0 08-11-2002 11:08 PM
