Go Back   Automotive Forums .com Car Chat > GMC > Sonoma | S-15
Old 11-24-2004, 01:19 PM   #1
slowbill
Angry 98 sonoma fuel pump
98 sonoma stopped,seems no fuel,replaced fuel filter,then fuel pump,still no go,will run if start fluid in air intake,checked,and fuel pump wont run,fuse is good,any help needed tks slowbill
slowbill is offline   Reply With Quote
Old 11-29-2004, 11:13 AM   #2
rlith
rlith's Avatar
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 98 sonoma fuel pump
Check your wiring on the fuel pump. Check your pressure at the shrader valve on the intake.
rlith is offline   Reply With Quote
Old 11-30-2004, 01:04 PM   #3
slowbill
Re: Re: 98 sonoma fuel pump
tks for info.wiring ck good,do you know what the press should be??
Old 11-30-2004, 05:44 PM   #4
rlith
rlith's Avatar
CPI should be 56-60 at start, 61-64 at idle/running
TBI=9-11 PSI either at start or run
Old 12-05-2004, 12:13 PM   #5
gbic1
Check the plug at the ignition switch. Had two loose ones.
gbic1 is offline   Reply With Quote
