Go Back   Automotive Forums .com Car Chat > Mercury > Villager
Old 11-22-2004, 03:21 AM   #1
sheikhg
Squeaking noise from engine when wheels turned completely to one side....HELP!
Help! I get a squeaking/squeeling noise from the engine when the wheels are completely turned to one side and can't go any further, left and right side. The noise will occur whether the engine is hot or cold. I also recently had my CERP belt changed!!!
Thanks!!!!!
sheikhg is offline   Reply With Quote
Old 11-22-2004, 03:33 AM   #2
hotrod_chevyz
hotrod_chevyz's Avatar
Re: Squeaking noise from engine when wheels turned completely to one side....HELP!
Check and make sure your belt tension is tight,you may have a bad belt tensioner or a failing power steering pump.Check your power steering fluid for proper fluid level.Stoppers are typically installed on the suspension to keep the steering components from working out of range.But i do not think this is the problem in your case
hotrod_chevyz is offline   Reply With Quote
Old 12-14-2004, 08:54 AM   #3
HRUIZ617
Question Re: Re: Squeaking noise from engine when wheels turned completely to one side....HELP!
ALSO HAVE YOUR RACK & PINION CHECKED IF YOU HAVE ENOUGH STEERING FLUID AND YOUR STEERING PUMP IS WORKING OK...
HRUIZ617 is offline   Reply With Quote
Old 01-30-2005, 02:40 PM   #4
VILLAGERS4ALL
Well your going to get some chirp from the belt when you go full lock on the wheel. it is not made to do full lock all the time, some small belt noise is normal . LOTS OF GRINDING AND RUMBLING IS NOT,,,
VILLAGERS4ALL is offline   Reply With Quote
Old 01-31-2005, 05:43 PM   #5
IH8SPM
IH8SPM's Avatar
You may also have a water pump going bad. If you are over 100k it time and most likely is the cause. The antifreeze poors out the bottom of the pump tru a weep hole onto the belts and can sometimes make it seem as if it something else. You well most likely not even see the fluid when you look but after I changed the timing belt and belts it all went away.
IH8SPM is offline   Reply With Quote
