Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 10-11-2004, 08:09 PM   #1
wickedplastikman
which cam is the intake cam?
i just bought some used gsr cams for my car. how do i tell which cam is the intake cam and which one is the exhaust cam? how can i tell the two apart? does it even matter? the cams are off a 96 gsr. thanks
99 teg ls turbo:
Drag gen III turbo, Blitz BOV, Blitz Boost Controller, AEM Standalone ECU, MSD Ignition, MSD Blaster SS Coil, MSD Cap, Skunk2 Intake Manifold, AEM Fuel Rail/Fuel Pressure Regulator, ACT XCT Clutch, ACT Aluminum Flywheel, Nex SS Coilovers, Thermal Stainless 3" Exhaust, Skunk2 Short Shifter/Knob, Rota 15" Black Slipstream Wheels, Falken Azenis Tires, Brembo Rotors, Axxis Metal Masters, Type R Wing/Seats, VIS Carbon Fiber Hood
wickedplastikman is offline   Reply With Quote
Old 10-11-2004, 10:46 PM   #2
LSfrankie
Banned
LSfrankie's Avatar
Re: which cam is the intake cam?
the one closest to the intake is the intake came. the one closest to the exhaust manifold is the exhaust cam. if you think about it, it makes sense
LSfrankie is offline   Reply With Quote
Old 10-11-2004, 11:48 PM   #3
CivicSpoon
There is no Spoon
CivicSpoon's Avatar
I believe he ment how he can tell the difference between intake and exhaust of the new cams he has, so he can put them in his motor in the correct place.Wow, almost sounds like you were actually trying to help someone...
CivicSpoon is offline   Reply With Quote
Old 10-12-2004, 12:47 AM   #4
LSfrankie
Banned
LSfrankie's Avatar
Hmm solid point. i think the only way to tell is to measure the lobes with a micrometer... intake lobes are slightly larger.
Old 10-12-2004, 01:41 AM   #5
wickedplastikman
yeah, thats what i meant. the cams i bought are obviously not in a motor right now. so you are saying that i need to measure them with a micrometer and the bigger one is the intake cam? is there any other way? honda usually makes things simple so i am hoping that they somehow marked them.
99 teg ls turbo:
Old 10-12-2004, 01:48 AM   #6
LSfrankie
Banned
LSfrankie's Avatar
I am pretty sure that is the only way... measure the VTEC lobe and the intake is the larger of the two. its a pretty small difference but close to 1mm.
Old 10-12-2004, 01:49 AM   #7
integralover
integralover's Avatar
if you look on the cams usually toward the non cam gear side it will have an I for intkae and an E for exhaust.
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
integralover is offline   Reply With Quote
Old 10-12-2004, 01:51 AM   #8
LSfrankie
Banned
LSfrankie's Avatar
I had some ITR cams not too long ago and they had no such markings
Old 10-12-2004, 01:54 AM   #9
integralover
well my cams are like that. well not sure about the vtec cams then
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 10-12-2004, 01:58 AM   #10
LSfrankie
Banned
LSfrankie's Avatar
Ok well if there is no markings to differentiate between the two, measuring is the best alternative
Old 10-12-2004, 07:45 AM   #11
boosted k20
boosted k20's Avatar
just look at the ends of the cams. on one of them u will see a slot at the end. this slot fits onto the shaft of the distributor. this is the intake cam. other one is obviously exhaust cam. cam can only go in one direction in the motor!
www.MEDIUMRACING.com
boosted k20 is offline   Reply With Quote
Old 10-12-2004, 04:15 PM   #12
wickedplastikman
ahh! thanks.
99 teg ls turbo:
