Go Back   Automotive Forums .com Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 10-10-2004, 01:00 AM   #1
k3smostwanted
Z Cars Fanatic
k3smostwanted's Avatar
Send a message via AIM to k3smostwanted
Cat-back loosening???
well...i was thinking about my exhaust and i had a question.
does anyone have problems with the exhaust loosening from the mid-section on their n/a z32?
reason: about once a month i have to crawl up under my car and re-tighten all 4 bolts that connect the cat-back to the mid section. all 4 bolts get pretty loose and everything starts rattling really bad. anybody have an idea of why this is happening?
ZedEx Crew Member #4
k3smostwanted is offline   Reply With Quote
Old 10-10-2004, 01:10 AM   #2
Broke_as_****
Broke_as_****'s Avatar
Just old wore out parts from the sounds of it. Replace the nuts if you can find some with the same size and thread. Also, put some locktite on the threads next time you tighten it up. If you really just don't want to deal with it just have it welded together.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Broke_as_**** is offline   Reply With Quote
Old 10-10-2004, 01:32 AM   #3
DeleriousZ
DeleriousZ's Avatar
Send a message via MSN to DeleriousZ
Re: Cat-back loosening???
bah! who needs mufflers.. just weld a pipe onto each side and run it right out the back
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
DeleriousZ is offline   Reply With Quote
Old 10-10-2004, 02:30 AM   #4
k3smostwanted
Z Cars Fanatic
wouldnt lock-tite enable me ever to get it loose again?
ill try new gaskets and bolts if i ever get my car back. its been 3 f***ing weeks.
Old 10-10-2004, 02:37 AM   #5
Broke_as_****
You can break a nut with Locktite on it loose, just takes more effort, which is kind of the point. A couple bucks of new bolts should work. If its still somehow coming loose after that then perhaps you should look into how its getting thrown around so bad that it keeps coming loose.
Old 10-10-2004, 02:49 AM   #6
k3smostwanted
Z Cars Fanatic
i was thinking that maybe my cats were clogged just a little. just enough where it wasnt releasing the exhaust as fast as it needs to so it is building up pressure in the pipes. kind of having a pushing effect on the rest of the exhaust. i dont know if that makes any sense. but it was a thought.
Old 10-10-2004, 03:06 AM   #7
Broke_as_****
It would take a hell of alot of backpressure to do that, and if you had that much backpressure, you'd probably just stall the engine. More likely its just that the bolts are worn from being jerked around and coming loose then retightened. Might want to check how the cat-back is fitted in there, if its not fully supported on all the mounting points then it may be putting more pressure on the bolts, making them support more of the weight of the cat-back then they should be.
Old 10-10-2004, 02:24 PM   #8
k3smostwanted
Z Cars Fanatic
yeah the exhaust is fully connected. ill change the bolts and gaskets and see what happens. my exhaust is rather old i think. hopefully i can borrow somebodys video camera and get a video of it on here.
freak, ill trade you cat-backs. stillen for un-known...
