Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora
Old 09-29-2004, 08:50 PM   #1
nicoleos
Question Rattle noise with reving
My 95 makes a rattle noise whenever i rev the engine. Whether i am in gear or in neutral, the noise is very annoying. It doesnt do it all the time, but for the most part. I was wondering if it was a loose spark plug???
nicoleos is offline   Reply With Quote
Old 09-30-2004, 04:26 PM   #2
boschmann
Re: Rattle noise with reving
Exhaust rattle, accessory bracket? Or, deeper inside the engine? Have someone rev the engine while you try to localaize the area it comes from.
boschmann is offline   Reply With Quote
Old 12-05-2004, 06:38 PM   #3
ipath43
Rattle/Buzz
My car does a Buzz at around 3,000 RPM, I'm pretty sure its my exhause manifold's heat sheild. There's not much you can do to fix it.. but you could buy a new one, or fiberglass raps, for the header pipes
ipath43 is offline   Reply With Quote
Old 12-15-2004, 01:27 PM   #4
IowaHawkeye24
My car rattled while shifting out of first into second and from second to third and i located the problem as a heat shield right behind the engine towards the back. I took it off and it sounds great now. By the way it's a 96 GL 2.0L 8v
IowaHawkeye24 is offline   Reply With Quote
