Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 06-10-2004, 03:42 AM   #1
pix
Question info on 6 disk changer
can someome please tell me which wires are which on a 01 Xterra 6 disk changer, im looking for a wiring diagram or if some one knows which is the remote wire and which is the power and ground. Iv never delt with a stereo that was so confusing before.
pixley7@aol.com
pix is offline   Reply With Quote
Old 06-12-2004, 11:21 AM   #2
gregory1041
gregory1041's Avatar
Re: info on 6 disk changer
I here ya...welcome to the wonderful world of Nissan wiring logic. I have an 04 Xterra and I learned not to trust the volt meter when it comes to finding a ground. I did a continuity test between one of the wires and the chassis and it showed that it had connectivity; however when you turn on the ignition, it was now 12V...go figure.
If you are putting in an aftermarket deck, there are a few things that I learned. My OEM deck has no ground wire; it used the frame as a ground. I found this out when I plugged the OEM radio back in, and it wouldn’t turn on until the metal on the radio touched the frame.
My Xterra has 2ohm factory speakers; this of course would blow just about all the aftermarket decks out there (unless you use an external 2ohm stable amp).
I am unsure what the 2001’s have, but you might want to check it out just to be on the safe side.
gregory1041 is offline   Reply With Quote
Old 06-12-2004, 11:26 AM   #3
gregory1041
http://www.crutchfield.com/cgi-bin/S...3000&s=0&cc=01
Crutchfield sells an adapter that might work (this is the one that I used).
Nissan 95 & Up
Old 06-16-2004, 12:54 AM   #4
pix
Angry Re: Re: info on 6 disk changer
I thank you for the info. yeah this is getting to be a real pain in the ass triing to figure out what is what. I dont want to change my radio i just want to hook up an amp and sub because the radio sounds like crap. I guess im just ignorant when it it comes to electronics.
Old 06-16-2004, 11:39 AM   #5
OffroadX
Send a message via AIM to OffroadX
Remote wire? You mean for the steering wheel controls? Those would be pins 9 (- yellow w/ black stripe) and 5 (+ yellow/red) on the 16-pin white connector.
Power connections (+) are pin 6 (red/yellow) directly from the battery, and pin 10 (green/red) switched from the ignition, and ground is via the unit's case. Pins 7 (- pink/black) and 8 (+ blue/red) connect to the illumination circuit for dimming control when the lights are on.
The 6-pin white connector supplies the rear speakers, while the white 10-pin connector supplies the front speakers, power, and illumination.
OffroadX is offline   Reply With Quote
Old 06-18-2004, 01:54 AM   #6
pix
thankyou thankyou thankyou that was exactly the info i was looking for. what i ment by the remote wire was the ognition wire. Iv never realy delt with a stock radio, most of the radios iv delt with have a blue and white remote/ignition wire basicly the wire that turns of the amp when the car is turned off
but once again i thank you
Old 03-14-2005, 12:03 PM   #7
bartchilders
Another thanks here - I was looking for this info as well.
bartchilders is offline   Reply With Quote
