| Latest | 0 Rplys |
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs |
05-18-2004, 01:55 AM | #1 | |
+Size tire inflation pressure ?
Hello there,
I have a 03 Pathfinder LE , OEM 245x65x17 105S on a stock 17x8.0 with + 20 mm offset, it should be 30 psi, now i will be running on momo twin suv 20x8.5 rims with a + 9 offset and Toyo proxes s/t 255/45/20 105V any idea about these issues :- 1-Can i use the original trie pressure monitors," i think these have a minimum air pressure setting of 22 psi". 2-What will be the air pressure on the new setup ? 3-Would i feel any rubbing due to the bigger size rims and tires ? 4-Are the traction control , VDC and suspension will be affected in a bad way.? I thank everbody in advance for their kind help., Cheers. |
05-20-2004, 01:31 PM | #2 | |
Registered User
Re: +Size tire inflation pressure ?
i'd be careful about going to oversized rims and tires i've heard it throws the handling out of wack...real bad for wet roads. although it will look cool!
05-31-2004, 10:16 PM | #3 | |
Found the answer
Just got reply from ToyoCanada tech. support team.
for that size and since it is a reinforced edition, minimum pressure will be 39 PSI, so for evryone installing a larger wheels &/or tires the maker of the tire knows better you can not use the oem inflation pressure nor the Maxi. pressure stamped on the tire, well i am glad that they answered me before i install these tires. |
